Getting stuck in rally fields (1 Viewer)
funflair
19,303
30,066
Guisborough
MORELO palace
since 2012
Ah right, well I wonder why the Police, RAC, AA and the judge didn't agree when a tugger blamed Top Gears advice after he'd seen it on Top Gear. Apparently laughter heard for hundreds of miles because he believed them. He got done for careless driving.
I would be interested in reading up on that if you have a link please, speed up was always the advice given and is the same principle as the Alko ATC anti-snake system.
Martin
Vanman
1,665
3,914
Runcorn
Roadscout R PVC
March 2017
Maybe it's because he was doing 100 mph down the motorway at the time ;)
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
They are optional on all motorhomes, it's just that not everybody chooses them.
Martin
Probably on newer ones. Obviously an expensive option. Possible good idea IF a moho was fitted with them but had the OP had them then I assume they wouldn't have posted the question as they'd know to use them and IMO, I'd think most Moho's didn't have hydraulic levellers on them. If OP did have them fitted then the post would never have come up so I assumed they didn't have as I don't.
Vanman
1,665
3,914
Runcorn
Roadscout R PVC
March 2017
If you carried something for every eventuality then youd have no room for booze.
Relax and don't fret (y)
But isn't sobering up an eventuality that needs constant attention?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
It was a big thing at the time. He started snaking and remembering the Top Gear prog, speeded up and it became seriously worse till he turned it over. The increase in speed was blamed. If I remember, the C & CC also commented that it was wrong and the BBC stated that it was said light heartedly. I don't think the top end speed was mentioned so he may have been doing that but if he was at 70 mph and started to snake then taking it up one might just hit 100mph if he's trying to reduce the snaking.
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Sorry, I was just being a little playful this morning, the wink was the clue ;)
Thank you and whilst I did miss that, I'm not really sure that giving light hearted or false replies actually helps unless you make it absolutely clear because without a doubt, someone might just believe that advice.
Remember the American who sued the moho manufacturer because he said they sold it as fully automatic and it crashed when he left the drivers seat to make a coffee.
Zepp
1,673
3,260
Roaming
7 Years
You have bought the wrong motorhome if you get stuck , you need one of these :D Then you can pull all of us out with your new toy .
Jul 10, 2016
413
385
hucknall
Swift bolero 712sb
10 years
Always carry wine it's a great incentive for others to help.
Zepp
1,673
3,260
Roaming
7 Years
Had a good look at that one at Caravan Salon we were tempted.
Also had a look at them but not sure if they are worth the extra cost and I would be scared to go off road incase I damaged the body work.
Lenny HB
53,309
149,502
On the coast in West Sussex
Hymer B678 DL
Price wise not too bad for what they are offering but you would need ear plugs off road or wrap all your contents in cotton wool.:D
Feb 24, 2013
13,054
101,383
Bolsover, Derbyshire
Hymer S800
not long enough
Make sure you know where your towing eye is stored, or that you even have one
Every time I read threads relating to needing a tow I keep saying I must make sure I know here mine is, then I have another doze and forget to check again
Will try and do it today now (y)
It must be nearly impossible to tow some MH's without one
May 21, 2008
4,270
7,338
Oxford
WildAx Constellation
Since 2008
If on your own, I suggest, with the greatest respect of course, that you don't park where you might get stuck.
If you are on a "rally" field and get stuck, willing help won't be too far away, unless you have been horrid to everyone all weekend.
JJ :cool:
In Cornwall a couple of years ago we arrived at a small campsite which looked suspect to me, but the owner assured me it was fine and our PVC wouldn't get stuck. We got stuck immediately while backing on to our pitch. The owner then produced his Ford Focus to pull us out!! What a joke!.. Luckily the tugger with the 4 wheel drive was willing to do it ...
Apr 13, 2012
5,536
18,751
Mobilvetta Euroyacht
1996, then break 'til 2011
(y)(y)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
I've got one of the 'track' thingys.
Like this??
May 22, 2015
1,424
2,589
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
A right. So it's not the lightweight tirfor but also a ground anchor and a cable I assume. I don't have a problem with the weight aspect but space is at a premium in our moho.
And if there was a place for a ground anchor and you just happen to have enough cable too, it's also possible, if using the logic of 'if in doubt, flat out' then some very expensive damage could be caused to the engine and/or gearbox possibly?
Mind you, if you're going into those situations knowingly then carrying your own solution is a must. I personally wouldn't willingly go into that situation but if I was going as in wild camping then I probably would carry. My own choice is to go elsewhere
Aluminium ground anchor and plasma rope, you haven't got to take any of this gear or any advice for that matter.
If you don't want to go off road then don't!!
Jul 29, 2007
6,549
39,583
Ipswich
RV and PVC
30 years
Years ago, (well about 40) I worked on BR mending the on-track maintenance machines, and getting to them was sometimes a problem.
This particular Sunday I got stuck in a wood miles from anywhere on some boggy ground, after a while achieving very little I had a think. Got loads of rope, so I looped it around two trees 30 or 40 feet away where the ground was firmer, got some wood under one wheel, jacked it up and wound the rope once around the wheel, did the same with the other, turned the wheels till the rope went tight then lowered them down, engaged gear and gently let the clutch out, and it worked! Pulled on to the firmer ground, retrieved the rope and went home. :)
Bilbat
54
56
Solihull
Lowline
Since 2014
We're insured through caravan guard which includes breakdown insurance and also covers being towed off muddy fields, so they told me when I renewed this year.
Bobby22
Bobby22
1,537
6,408
Scotland
Rapido 680ff
since 2013
One or two practical answers £4500 seems a bit extreme though @Techno . But.....
has anyone ever got THEMSELVES without out AFTER getting stuck.
I have noticed people trying to get things jambed under the front wheels but always had to get pulled out in the end.
Derbyshire wanderer
1,285
2,383
Derbyshire
C class
15 years
I suspect that his defence was based on using the go faster method as the reason for towing at a speed that the prosecution decided was careless.
Not familiar with the court case but would also be laughing if someone told me they had reached a very high speed doing this.
As I said above, if the crashing speed was deemed too high for towing then procecution was justified.
I have often seen caravans and trailers at 70mph which is 10mph quicker than the law allows as a maximum.
Not going into the dynamics in detail but a slight sway at low speed increases its effect and velocity as speed increases causing the much lighter trailer or caravan to have an effective weight well exceeding the towing vehicle. Tail wags the dog and over it goes
