Getting a second battery. (1 Viewer)
michpiggy
120
108
West lancashire
Elddis advante 285
2 and 1/2 years of owning a motorhome.... 12 years owning a touring caravan
Hi all
If we want to put a second battery and solar panel on the motorhome do we need to replace the battery that is on as well as get a new one so they are both the same age? or can we just buy one and it work ok?
Michelle and Andy
Oct 15, 2012
10,185
57,386
Market Harborough
C Class Laika Ecovip 7R
Would have thought that you would need to get two batteries or the old one might draw from the new one but I'm sure someone will be along shortly to put you right. (y)
Don Quixote
2,966
5,258
Lost in La Mancha, Spain
VW T6 Campervan
How old is your original battery and what size is it? - have you ever discharged it below 12.2volts ?
Old school will say you need to replace it with two new ones........ but without details cannot comment more.
michpiggy
michpiggy
120
108
West lancashire
Elddis advante 285
Not sure yet we pick the motorhome up on the 28th
We will have a look at it and take photos
Jul 27, 2011
145
197
Kilmun, Dunoon
Knaus Sport TI
Since 2012
Hi there... I installed a 100 watt solar panel which is connected to one of these Broken Link Removed a dual battery charger. The two batteries are connected to the charger are both of bog standard 95Ah sealed Varta batteries installed a year apart. The batteries supply 1.2 kw static invertors Broken Link Removed which gives us easily a full evening of power for our TV and satellite receiver. System has been installed two years now working like a dream.
You may want to look at www. aliexpress.com where you may find them even cheaper.
Hope this helps.
