German Translation (1 Viewer)
slickmouse
293
Planet Mars next 2 Uranus
Winne/DAF Coach
Hi Guys
I bought an external BBQ point and there is writing in German on it (at least i think it's German) i think i know what it says but can anyone tell me for sure
Das offnen und schlieben der absperrarmatur ist nur dann moglich, wenn der stecknippel im kupplungselement verriegelt ist
Thanks:Eeek:
superk
495
57
Devon
Van Conversion now sold
8 years
The best Google Language can do:
The Schlieben open and the valve is only possible if the plug nipple in the clutch element is locked
:Smile:
Keith
N
N Luyetund
According to an on-line free translator...
That open and schlieben for the stop valve is possible only if the connector is locked in the clutch element
I suspect you've misspelled the word schlieben... it's probably schliessen which translates as closed or locked...
hope that helps:winky:
sandyketton
16
South West Suffolk
C class
Eight years but ten years tugging in an earlier life
That open and schlieben of the absperrarmatur is only then moglich if the stecknippel is locked in the kupplungselement
This translation is worse than the original ! Found it in Free Translation service.
Good luck with this
slickmouse
slickmouse
293
Winne/DAF Coach
Yes, I think it means
You can only open the valve if the gas cannister or bottle is connected
if you hear of a large gas explosion in Central Scotland on News at Ten you know who it was
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
What it means is the tap of the BBQ point can only be turned on when the connecting hose nipple is locked into the valve outlet. Its pretty much a standard safety design feature on BBQ points.
D.
Phil
226
Herts
10 years
The letter that looks like a B with a tail ( like the Greek Beta ) is an esszett and normally sounds and is often written by the Germans as a double s . As mentioned above schliessen is the verb to close or shut.
Phil.
43,295
49,263
yep its misspelt. if you change the spelling in babelfish it gives the correct word....closed....
the reason the other words wont translate is the english keyboard doesnt have 'umlauts' two little ticks ABOVE an O, A, or E which changes the way the word sounds.
without them the translator doesnt know the word so just puts in the original.
N
N Luyetund
Danke sehr Pappajohn (das hab ich gewissen)
N
N Luyetund
Try this one Ach du liebe krysaik:ROFLMAO:
and this one Auf wieder bye bye:winky:
Oct 2, 2008
4,465
7,931
Salopia
Duro 6x6 Overlander
since 1968
The word for word is as follows , as german word order is like old english (ala chaucer/shakespeare ) :Smile:
The opening and closing of the operating valve is only then possible when the connector in the coupling engaged is
Obviously not many german motorhomers on here :roflmto:
