scotjimland
- Jul 25, 2007
- 2,246
- 9,758
- A Woosh bang
I have a copy of the book but this on line resource is very good.
Link Removed
Link Removed
Link Removed
Brian,
Thanks for that it worked OK.
It's a very steep learning curve for me is the Sat Nav, my problem is I don't understand the terminology some of the time. :Confused:
Somebody recommended this site http://www.obliquity.com/astro/osgb.html for converting post codes & OS map ref to Lat/long.
It would help if all the sat navs used the same co ordinates, I suppose that is too much to ask.
I use Autoroute 2001 as the later versions do not cover Turkey.
Regards
Don
Hi, Don
Great that it worked, you can also change then way Autoroute displays or accepts the coordinates, I don't understand this full myself, but if you want to have a look, follow the same description as i gave before and when you get to the drop down list under the word "tools" chose the word "Options" rather than location sensor and then you should have another menu which will allow you to alter the way the coordinates are interpreted
hope that helps
Brian
