Genny: any good? (1 Viewer)
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Saw this on fleabay: item No. 270638248382.
After being offered a plug in by Bob (of Bobandjane) at Newark I decided they are a useful bit of kit.
This one is "pure sine wave", whatever that is.
Is it any good?
Kippors are noisy, Honda expensive.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Is it any good?
Spec is OK quality unknown. I've got one similar, hardly used it but it does work OK. With these unknown ones we take a gamble long term on life and spares.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
Thanks Brian.
The video blurb looks good, but then it would, eh?
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
It looks good for the money, certainly for occasional use in the wild maybe.
Is this a case of "If it looks too good, there must be a catch".....?
I could be tempted though - thanks for the link.
johnp10
johnp10
7,774
15,181
North Lincolnshire
8 years ish
I was thinking occasional use.
Looks ok, but I'm no authority on Gennies nor electrikery.
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
How about this one......
Link Removed
Would it charge my toothbrush???:Eeek:
JockandRita
11,447
149,907
Lincs/Cambs border
N+B Flair 8000i
Since May 05 (Ex Tuggers).
Hi John,
[ame="http://www.youtube.com/watch?v=pDh0ZaN-wNQ&feature=related"]This chap might know more about the Kiam 1000i genny[/ame]:ROFLMAO::ROFLMAO::ROFLMAO:
Jock.
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Would never say don't buy a product like that - what I can tell you is we have had a cheap ones before and they have always worked and they have always broken down after 20 or 30 hours of use. They have always been impossible to easily source spares and so have ended up being scrapped. My advice would be to get a known name that you can easily get parts for or repaired it will be cheaper in the long term - you can always bet too that the cheaper ones are the ones you can hear on a rally field
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Link Removed
That's a non-sinewave one, which means there is no electronic stabilisation so some risk if you connect electronic gadgets, like the on board charger.
A "pure sinewave" on really means "electronically stabilised for voltage and frequency".
A non "pure sinewave" one will give a sinewave output but it will very in frequency with the revs of the motor and so will the voltage.
Jim
Ringleader
Jul 19, 2007
36,324
130,305
Sutton on Sea, UK
Adria Panel Van.
Since 1988
Lots of people buy a cheap genny "because they will only use it a couple of times a year" In my experience if you are only going to rareley use it, buy a Honda. The cheap ones are better if you use them regularly. A Honda will start after being stored for months with just a few pulls, my experience with the cheapeys is that once you leave it for six months it dies, often forever, maybe I've just been unlucky, (but lucky with Hondas:Smile:)
haganap
12,754
26,415
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Would have to be with Jim on this one.
Our Honda is a gem, has performed without fault at 2300m in -25 degrees, to the French coast in temps of 100 degrees,
Doesn't seem to matter what I do to it, it just keeps working.
Ive started to learn that if your going to buy something, buy it once.
Quality is remembered long after the price is forgotten.
Buy a honda and it will live forever, :thumb:
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
First time I came to use our cheapey in anger it would not start. But I was talked through stripping and cleaning the carb by their service guy. He said that every spring he has a nice little earner cleaning carbs with a bit of dried gunge in the jets. The hole in the jet is just one or two hairs in size.
Another tip he gave me, put a rag over the filler and blow like mad. They have a vacuum petrol pump so the first half dozen pulls is just getting petrol to the carb.
I'm sure we all know that petrol left for months goes stale. Drain and fresh petrol also a good idea.
Remove plug, clean it then heat it up some, replace quickly. This stops it getting wet.
wivvy's dad
3,205
1,795
48.066895,12.862673
Spoken liike a TRUE motorcyclist
:thumb:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
run it dry
i just drain most of the fuel out then start the genie and leave it running until it runs out of fuel that way there is no fuel in it to go stale or gunge up the carb.
champers
4,224
8,425
Skegness, UK
Frankia i650 FD
Since March 09
There is this Kipor on fleabay 220766174906 £255 +10 P+P next day delivery brand new
Road Runner
1,143
1,445
Europe
yes
Since before Motorhomefun
My Kipor was going strong and only oil changes since new in 2005 and started every time BTW, it was so good some scum cut the security cable and nicked it.
Now C'mon do scum nick rubbish:winky:
