Genie's in sick bay (1 Viewer)
Mags52
1,433
1,731
Melrose Scottish Borders
Hymer B774
Since 2010
When we got home from Chester we saw that there was oil on the (brand new) monoblock right where we park Genie the motorhome. We'd noticed 2 or 3 clutch slips on the 400 mile journey but not regular and not when we were pushing it in 4th or 5th (only did that to test the clutch).
Phoned the garage that look after her and the guy did that sucking through the teeth thing that lets you know it's probably expensive. Bummer.
She's in there now having a diagnostic.
:sick:
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
They phoned and said it was the sump gasket. Being replaced tomorrow. I guess it could have been worse.
jollyrodger
6,282
26,419
Devon/Cornwall
'Obby
Since 1968'ish
Oh well bet your relieved will get an oil change at least might as well change the filter at the same time
Jaws
23,836
72,471
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Well sadly I doubt that will cure the mentioned clutch slip.. Be prepared for a near future encounter with the garage again :(
Feb 16, 2013
19,733
52,017
uttoxeter
ambulance conversion
50 years
Liked this but not really! Did you tell them about the clutch slip, if so ask them what a sump gasket has got to do with it!
Mags52
Mags52
1,433
1,731
Hymer B774
Since 2010
I told them about the clutch slip. As it had only happened 3 times in 400 miles he just said wait and see. That will be the second clutch in 34k miles. And before anyone asks, no we don't drive with a foot on the pedal but we have had a remap. (she says opening a can of worms)
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
I have heard people say remapping and putting chips on vehicles can put extra wear and tear on clutches & engines...
Some clutches can be adjusted, I'd just keep an eye on when it seems to slip... maybe when it's under extra load?
Big Lad
106
74
Tamworth
Lunar Roadstar 570E
You can normally tell if a clutch is on its way by where the bite is on the pedal. If it's quite high up, it can mean a sign of wear or may just need adjustment.
Just keep an eye on it.
injebreck99
1,706
1,795
norfolk
Low profile C Class
Since 1997
Not while you are driving though obviously!
