Generator Dilemma...
Discussion in 'Tech/Mech General' started by JJ, Nov 1, 2012.
  1. JJ
    JJ Funster
    May 1, 2008
    15,013
    26,989
    The Hymer doesn't have an oven.
    So, at a show, I bought a 700 watt Tristar electric oven which is BRILLIANT.
    My Kipor 1000 runs the oven a treat.
    My Kipor 650 doesn't.
    The float needle (and/or valve) are playing up in the 1000 (runs perfectly but fuel overflows via the overflow tube.)
    The float needle (and/or valve) are NOT playing up in the 650.
    Research shows a new carb for the 1000 is around £45.
    By looking it seems the carb on the 650 is the same.
    With my semi-planned Christmas/New Year trip approaching, should I just swop over the carbs for the trip (an easy to do and quick job) and thus have PCC (Pie Cooking Capacity) or...
    ...should I try to bodge the 1000 float needle or...
    ...should I throw £45ish at the problem and get a new carb (can't find a seller of float needles and seats only) for 1000 or...
    ...should I go without Pies for the Festive season?
    JJ :Cool:
  2. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,188
    2,003
    Devon
    :Rofl1::Rofl1:
    That's a tough one.
    Ermmmmmmm
    Not really sure.:Rofl1::Rofl1:
    • Like it Like it x 1
  3. JJ
    JJ Funster
    May 1, 2008
    15,013
    26,989
    Couldn't you and Alan come out here and cook the pies for us? Would save a lot of thinking... :Rofl1:
    JJ :Cool:
    • Like it Like it x 2
  4. lesleyjean
    lesleyjean Funster
    Jun 21, 2008
    2,188
    2,003
    Devon
    Would love to, but we are still stuck In Benidorm with a broken exhaust.:cry:
    Alan said,
    "Christmas wouldn't be palatable:Laughing:Without pies".:Rofl1:
    Have a great Christmas.
    :party2::party2::party2::party2:
  5. Sundowners
    Sundowners Funster Life Member
    Oct 30, 2007
    2,372
    1,458
    Suffolk
    Is the float leaking - i.e. is it full of petrol or is it the needle/seat causing the problem?
    We have heard that Honda parts are interchangeable, may be you can just buy the part you need from them.
    If the float is leaking maybe you can Araldite it up.
    Nigel and Pamala
  6. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    Usually only one thing causes flooding JJ.......a speck of dirt/grit in the needle valve/seat.
    nor often they wear out due to such little use.
    a good blast from both ends of the inlet with a high pressure airline, not the tyre inflater type, should clear it once the float and needle are removed...simple job.
    the 1000 and 650 carbs will have different size jets in the identical body
  7. Stephen & Jeannie
    Stephen & Jeannie Read Only Funster
    Aug 27, 2008
    4,198
    3,262
    Gobowen near Oswestry !!
    Sadly for JJ, It's a Kipor !!!
    Guess who's just found out how to highlight ! What's next for the old fogey ( moi ) !:Rofl1::Rofl1::Rofl1:
  8. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    Dont do generators JJ so cant help with that. What I can help with though is a Kampa Roastmaster oven and 2 burner hob which I fitted in my garage. Works a treat and came from JC. Its designed for camping and just couple it up to one of your refillable gas bottles.
  9. Taran_Las
    Taran_Las Funster
    Mar 26, 2009
    6,637
    5,701
    Yr Wyddgrug
    A faulty (punctured) float can also cause flooding.
  10. Sundowners
    Oct 30, 2007
    2,372
    1,458
    Suffolk
    Kipors are copies of Hondas that's why the parts are interchangeable.
    Nigel and Pamala
  11. Heyupluv
    Heyupluv Read Only Funster
    Oct 7, 2008
    3,860
    1,583
    France,
    JJ.... take off the Carb... dismantle and clean out the jets....blow out ..with air line...then re-assemble ....when taking the float chamber off...the sump under the carburetta ... just be careful the the pin inside that holds the float does not drop on the floor ....dismantle over a large clean cloth..most likely a minute piece of dirt.
    If you can get to the carb sump bowl easy enough ....then just undo the nut ...drop the the bowl (put some cloth under to catch any float pin that might drop)...clean and re-assemble...leave the card in situe,
    [​IMG]
    http://www.ebay.co.uk/itm/Kipor-Pet...trial_Tools_Generators_ET&hash=item19c8d99dcc
  12. GJH
    GJH Funster Life Member
    Aug 20, 2007
    27,349
    34,949
    I'm afraid it might mean shelling out some cash. Obviously going without Pies for the Festive season is a non-starter.
  13. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    [​IMG]
    :thumb:
    Just undo the centre nut and drop the bowl .....simples young-un
  14. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    agreed, but then it wouldnt run at all.
    the easiest way to check for punctures is remove the float and hold under warm water.
    the air in the float will expand and bubbles appear at the hole.
  15. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    have you not got an oven in the wagon JJ????
    if so problem sorted.
  16. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
    the first line of JJ's opening post......:Doh::Laughing:
    Edit.....Oh, I see what you mean.....Wagon/Hymer :Doh::Blush:
  17. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
  18. Heyupluv
    Oct 7, 2008
    3,860
    1,583
    France,
    Yes John but surely JJ should be able to change the jets over:Eeek::Doh::Wink::Wink:
  19. pappajohn
    Aug 26, 2007
    30,252
    17,924
    YO11 2BD
  20. Stephen & Jeannie
    Aug 27, 2008
    4,198
    3,262
    Durrrrr !! My brain hurts !!!:cry::cry::cry:
