General Maintenance - DIY (2 Viewers)
43,329
49,444
Copperslip is perfect for wheel studs and nuts. It doesn't effect torque and prevents corrosion and ease of future removal. Used it for many years, both on our military equipment and my own vehicles. Well recommended. In fact I use it on almost every single nut and bolt I remove, it's that good :)
Would never use anything other than copperslip :)
Probably military training techniques.....
Same mistaken principle as....if it moves salute it, if it doesnt then paint it.
NEVER grease wheel nuts/bolts.
They arent greased at the factory for a reason...accurate torque rating of a 'dry' thread.
PP Bear
PP Bear
7,806
28,776
Kent, UK
Auto Trail Dakota SE
I've emailed the manufacturer of copperslip and asked their take on me using it on wheel nuts, studs and bolts. Used it for years and never once had an issue. The safety data sheet here Broken Link Removed clearly states that it allows the correct torque to be applied. Let's see, for my own peace of mind, what the manufacturers say :)
I hear what everyone says about coming out of the factory, however having suffered seized wheel studs before through corrosion, copperslip was the only sensible, safe answer....more to follow out of curiosity :)
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
I have done exactly the same with every vehicle I have owned and for the same reasons. Manufacturers have their own agenda and are most definitely not always correct. They assemble their vehicles with every fastener dry and the owner suffers the consequences when corrosion causes seizure. I do not believe that they do this so the correct torque can be applied. They supply a wheel brace with which it is close to impossible to release an un-lubricated wheel stud and with which it is also near impossible to achieve the correct torque on tightening. They supply a jack that is all but inadequate for its intended purpose with an unladen vehicle - and useless if the vehicle is loaded. I have to assume white van man doesn't get punctures when he's loaded. But they are always right:rolleyes:.
Feb 27, 2011
14,737
75,972
UK
Self Build
£30 for 3 hours work? When was this 1965?
D.
I was surprised as well... I think they charge by the job and honour it. They did quote £30 up front but the job turned very very nasty. I get it done every year now and it takes 1 to 1 and a half hours all in and it is always £20.
I talked to the young(ish) lad who did the work while he was working. He did an engineering apprenticeship at the same college I did my electrical one. Even had a few of the same Lecturers as me from over 25 years ago. I wondered why he was working at a tyre/exhaust place and he said he was well looked after.
I was extremely impressed with his knowledge and working ethos. He is what I would call an old school mechanical engineer in that he knew when to apply brute force and risk breaking something that could be replaced and knew when to apply subtle force such as heat or lubricant when an expensive component was involved. He is one of the few mechanics I am happy to leave to get on with things and not keep an eye on. He looks after my van very well. covering seats/steering wheels if he is dirty. He asks me if I am stowed away for travel before testing things on a drive. If I am not stowed he drives like a chauffeur and if I am stowed he drives it hard enough to test stuff quickly to keep the time down.
I am not sure how they do stuff so cheap but I have been using them for the last 5 years and they have never let me down and the price is either fixed up front or if they can't give me a fixed price they always come in well well under expectations. Because of this I will travel across the country to use them. I have never before experienced fast, cheap and good. Normally it is pick 2...
Edit: and in 6 years I have never once had to take it back to get anything redone/rectified. Now that is a first for me.
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Fair comment Grommett, I just wonder how they stay in business with pricing policies like that. Presumably they charge more on other jobs/people's vehicles.
D.
Feb 27, 2011
14,737
75,972
UK
Self Build
D.
Their main source of income is tyres. They are very quick on those and have a roaring trade. The mechanicing is not a major part of their business.
PP Bear
PP Bear
7,806
28,776
Kent, UK
Thanks for that, PP. I agree with you about the merits of copperslip and I've used it frequently (just not on wheel nuts:rolleyes:). Thanks for the advice.:)
Yes Dave Newell always says that he finds more breaking up than are worn out on motorhomes. I changed mine earlier in the year & they were starting to break up & detach from the backing plates.
I had to open my last tin earlier in the year. Only been carrying it round since 1976.:D Hopefully I'll die before I actually have to buy some. :LOL:
I emailed the manufacturers yesterday. Asked if it is ok and safe to use copperslip on wheel nuts, studs and bolts. They emailed back today and the answer is yes, so I'll carry on using it as before. Also looked at the safety data sheet and that confirmed it too :)
Apparently it can also put hairs on your chest too :)
PP Bear
PP Bear
7,806
28,776
Kent, UK
PP check front wheel arch for rust.Right at the top.mines 11 years old this year.both just starting.wire brushed back to bare metal.two coats of cure rust two coats of hammerite.Then a coat of hammerite underseal.
Checked and mine are ok, but I still cleaned it all down and undersealed it all with Hammerite underbody seal :)
Peace of mind again. Thanks for the tip :)
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Which manufacturer did you contact PPB, Fiat, Autotrail or the makers of copperslip?
D.
grumps147
1,840
2,448
St.Helens
Between
MH 12 yrs -Tent/Caravan 49 years
Used to drive a large van for a few years as part of a job. One of the first things was to try and change a wheel using supplied jack.
Not a Ducato, but no doubt very similar products.
It took quite a while to get the wheel nuts loose, after borrowing a piece of scaffold as lever extension.
When high enough to get the wheel off on a flat solid surface with no wind in a garage, the vehicle rocked on the jack so much I stopped very quickly and told our vehicle fleet no way was I ever going to do this out on the road. Within 20 minutes I was supplied with the number of a 24 hour mobile tyre fitter.
I imagined trying it on a windy M6 hard shoulder with additional wind wash from heavy's, it doesn't bear thinking about.
The first thing I check on my breakdown cover is that they will come out for a wheel change.
laird of Dunstan
1,464
3,953
lincolnshire
Rapido 9000DFH
ex caravanner
I remember the noise of shooting on a Sunday morning coming from Arborfield , I guess they intend filling in all that green space , I used to live and work not far from the garrison .
The land must be worth a small fortune
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
I agree with Bill, I'd be checking with Fiat rather than the grease manufacturer. As far as I'm aware Fiat advise clean dry wheel bolts and that is exactly what is specified on Autodata.
D.
Nov 18, 2011
11,862
43,022
Planet Earth
A van
Over 25 year's
D.
when I was abut 15 years old I was helping my old man he went off to diner when he came back I had nicely greased up the wheel studs.
till this day I can still feel the stinging pane in my ear and her his very words and the reason why not
I was fore 2HRS cleaning the studs with petrol and meth's to his satisfaction
I never helped him in his garage agene
bill
PP Bear
PP Bear
7,806
28,776
Kent, UK
was that the wheel bolts you copper slipped?
bill
Yes Bill. Glad I did as I had to remove all the wheels again to replace the brakes after finding the front broken. Also put some on the disc face so the wheels wouldn't stick again :)
