Gearbox oil?
Discussion in 'Fiat' started by LDV400, Apr 30, 2014.
  1. LDV400
    LDV400 Funster
    Sep 1, 2010
    80
    30
    fife
    I would like to change the gearbox oil in my 96 ducato 2.5td Swift royale any advice Please.
    Thanks Sammy.:thumb:
  2. DBK
    DBK Funster
    Jan 9, 2013
    9,218
    12,829
    Plympton, Devon
    I know nothing about this specific transmission but does the oil need changing? Most transmissions these days require no oil change and by trying to change it you just risk introducing dirt. I doubt there is even a drain hole.
  3. LDV400
    LDV400 Funster
    Sep 1, 2010
    80
    30
    fife
    gearbox oil
    devonbeekeeper the is m/h is a 1996 and there is a drain-plug, I was hoping that some one could have helped which oil it takes :Smile:
    cheers :thumb:
  4. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,156
    8,070
    DERBYSHIRE
    • Like it Like it x 2
  5. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,898
    6,158
    Mansfield,Notts
    Hi Sammy
    75w/90 Semi Synthetic is specified for your gearbox
    2.8 Ltrs from Bone Dry
    G
  6. LDV400
    LDV400 Funster
    Sep 1, 2010
    80
    30
    fife
    gearbox oil
    Thanks Geo,
    Thats just what i,m looking for :thumb:.
    Also thanks to jhorsf :Smile:.
    I did check up on some other threads but they were conflicting so it is good to get a good solid reply.
    Thanks again.Sammy.
    • Like it Like it x 1
  7. joner8888
    joner8888 Read Only Funster
    Jan 4, 2012
    2,190
    1,971
    somerset
    I changed mine in the winter.
    I read that maybe early Ducatos might have had water ingress into the box through a incorrectly directed drain pipe from the air intake under the windscreen.
    Drained it out easy enough and was not discoloured , so ok.
    The only way to refill is through a vent hole on top of the box which under a whole lot of bits and pieces.
    I had to measure out 2.8l into a pump dispenser with a tube and fitting.
    It may not have done many miles 40k but it`s been in there for 17years and oils back then are not as good as they are now :thumb:
  8. LDV400
    LDV400 Funster
    Sep 1, 2010
    80
    30
    fife
    What oil
    Hi joner8888
    Just a matter of interest what oil did you put in it and did you buy it local ?
    Cheers Sammy:thumb:
  9. joner8888
    Jan 4, 2012
    2,190
    1,971
    somerset
    80 sae semi synthetic :thumb:--I think I already had some in store
  10. LDV400
    LDV400 Funster
    Sep 1, 2010
    80
    30
    fife
    OIL
    Hi Joner8888
    Thanks for the info :thumb: Sammy
