Gearbox noise.
Discussion in 'Tech/Mech General' started by Billy23, Jul 16, 2016.
  1. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    On a planet...far, ....far away.
    I have a 2001 Transit 350 and have noticed that the gearbox is making a noise when I decelerate, it is fine under pressure, hard to explain the noise, bit of a rumble.
    Have one of you mechanical minded guys any pointers please. As I am on tour, do I need to worry big time, or is it likely to wine for a while but he ok?
    Thanks for any (informative) suggestions :)
  2. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,082
    2,922
    Kendal, Cumbria
    Are you sure it's the 'box? A, presumably low pitched, rumble sounds more like propshaft UJs or centre bearing (if it has one).
    • Like Like x 1
  3. Larrynwin
    Larrynwin Funster
    Feb 22, 2008
    8,792
    13,704
    Norfolk
    Try knocking it out of gear and hear if any different.
    • Like Like x 3
    • Informative Informative x 1
  4. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    Is the oil low that might be worth looking at
    but like previous poster it could be propshaft or CV joint dose it rumbil on sharp right or left turn
    Bill
  5. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Thanks for all your replies, having read them I now think it is the prop shaft, so I had better find a garage. Not sure how much I would expect to pay for the joints to be replaced but knowing my luck........it won't be cheap.:)
  6. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Ok, I have had a look underneath and there is hardly any movement when I try to twist the prop or any up and down movement. When I look at the 2 rubber bearings that hold the prop a third and 2 thirds along the prop, they seem to have some up and down movement.
    When I try to twist the prop with my hands it will only turn less than half an inch.
    Can somebody help anymore on the above information?
    I will mention that when I take it out of gear the rumbling is less but still a rumble.
  7. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    Carrier baring or rubber baring dry or universal joint
    Spray each baring with spray grease one at a time if it is one of the carrier bearing I would have both changed is their plenty of oil in the diff se90 gear oil or se80 gear oil
    Bill
    • Like Like x 1
  8. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    Off to bead just off night shift will watch this thread with interest
    Bill
  9. Steve
    Steve Funster Life Member
    May 8, 2013
    1,571
    1,850
    Compton Berkshire
    if it’s on the overrun and you can’t find anything else then a bearing in the gearbox (backlash) is likely to be the problem. Check the oil a change won’t hurt look at the old oil for 'bits' fill with new oil and additive may be a good idea. I f that doesn’t work then its let it develop or strip down/replace doing the clutch at the same time.
    • Like Like x 1
  10. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    I have sprayed the joints with silicone lubricant as it said it was ok with rubber, is that ok or should it be ordinary grease?
    I will move the MH tomorrow and see if it is any better.
  11. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,936
    17,600
    YO11 2BD
    Unless you dismantle the UJ spiders you won't get any grease in them.....Unless of course they have grease nipples fitted.
    • Like Like x 1
  12. ambulancekidd
    ambulancekidd Funster
    Sep 23, 2014
    609
    1,484
    Ayrshire Scotland
    Any of the lubricants might help & you won't do any damage. I'd be inclined to find a garage & let them diagnose it for you. Hopefully its a universal joint on the propshaft, these are usually quite inexpensive & don't take too long to fit.
    • Like Like x 1
  13. Ranger
    Ranger Funster
    Nov 2, 2008
    232
    195
    Lincolnshire
    If its only on overrun it may be diff whine especially when hot , having said that after many years of running various transits you expect them to make many and varied noises but keep going indefinitely.
    • Like Like x 1
  14. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,122
    3,528
    walthamstow east london
    its often going to be the dif on a transit
    • Like Like x 1
  15. Billy23
    Billy23 Funster
    Feb 10, 2012
    1,555
    2,823
    Well done @mitzimad go to the top of the class. I took the MH into a garage, they checked the diff oil - it was good - but noticed fillings on the plug, they said the the diff was the trouble. They said it should be ok for many miles and not to worry to much at the moment, I will of course need to get it done.
    Thanks guys for all the suggestions, we found it in the end.
  16. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,122
    3,528
    you will change it when its louder than the radio
    • Funny Funny x 1
  17. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    I sent you a pm the other day put sume of the additive I recommended in it and be amazed what it dose
    Bill
    • Like Like x 1
  18. Wildbill
    Wildbill Funster
    Nov 18, 2011
    7,235
    12,889
    somewhere
    Quoiting my own post hear put sume coper slip in the diff will help it Cote's the gering ian helps to reduce the noises
    It dose work mix it with sume gear oil I put t full tin in a diffaranchal think it is still running
    I only drive vehicle with issues so know how to bogie them to get bye withe them
    Bill
    • Like Like x 2
