gear box
Discussion in 'Fiat' started by psyfried, Jun 21, 2012.
  1. psyfried
    psyfried Funster
    Oct 30, 2009
    73
    34
    north yorkshire
    HI all
    can any tell me how to check the gearbox oil on a fiat 1995 2.5 TD :Smile:
  2. DP_JAY
    DP_JAY Funster Life Member
    Mar 17, 2010
    1,812
    1,030
    Cark, Cumbria
    Yes, drain it & refill it with the correct amount.
    That's it as there is No level plug.
  3. rainbow chasers
    rainbow chasers Read Only Funster
    Oct 30, 2009
    3,747
    1,721
    Mid Cornwall
    Set some of the old oil aside in a jar to check for seperation. Common fault on your age is water ingress caused by the scuttle drain emptying on the gearbox mount.
  4. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,323
    17,034
    Liverpool.
    It should be filled through the reversing light switch. There is what apears to be a drain and a level plug on the side of the gearbox. In fact there are 2 levels which must be filled ie 2 chambers. First drain the box and then refill with semi synthetic oil by taking out the reversing light switch. If you fully drain it will take 2 litres.
    If you don't do it this way,it wont be long before you start to have 5th gear problems as the 5th gear sits higher in the box.
    After filling there is a dipstick on top of the box.
