Lottiethehymer
I want to check my gearbox oil but haven't got a clue where to find to do it , can anybody help me , my m/h is a hymer b778 2013 , thank you in advance, Pam
Is there a reason you want to check the oil? Usually it isn't checked, which leads me to suspect you have an issue?Thank you guys for your replies, it is due for service soon so will leave it up to the professionals lol
IT should be checked, the gearbox usually has a plug in the side of it. To check or top up squirt gearbox oil into the box till it leaks out of the fill plug as its at the correct level.Is there a reason you want to check the oil? Usually it isn't checked, which leads me to suspect you have an issue?
Well, it should be checked, that's a different matter entirely, what I was saying is is generally isn't.IT should be checked, the gearbox usually has a plug in the side of it. To check or top up squirt gearbox oil into the box till it leaks out of the fill plug as its at the correct level.
Gearbox oil comes in a plastic bottle with a plastic tube attached for this purpose
Back in 1978 perhaps but not in the modern day, certainly not on modern Fiat vehicles as they don't have a level plug. Filled for life and unless there is a leak or the box is removed there is no need to bother.IT should be checked, the gearbox usually has a plug in the side of it. To check or top up squirt gearbox oil into the box till it leaks out of the fill plug as its at the correct level.
I must admit it's been a while since I have checked but not sure as long ago as '78Back in 1978 perhaps but not in the modern day, certainly not on modern Fiat vehicles as they don't have a level plug. Filled for life and unless there is a leak or the box is removed there is no need to bother.
D.
