Gear box crunch (1 Viewer)
S
Smudger 41
Hi does anyone know about any problems relating to gear box crunching on fiat ducato engines.Our swift kon tiki has started to crunch only between first and second gear and brownhills have put down to driving style which we know is complete bull***t because it didnt do it when we first bought it a year ago....Help.......:Eeek:
S
Smudger 41
only does it from first to second
43,295
49,268
sounds like its the 2nd gear syncro hub thats worn but it should also do it from 3rd to 2nd.
next time out try double clutching.....
press the clutch as normal but only move to neutral....release and instantly press again and try to get 2nd.....must be done as one smoth movement
press, neutral, release, press, 2nd, release.....takes practice but if it goes in smoothly id say it was the syncro hub.
could also try engaging 2nd at standstill instead of 1st.....if it wont go in then see the top sentance.
S
Smudger 41
Thanks for the reply..Can get all gears and change down ok..Problem only happens when pulling off from 1st to 2nd it crunches....
43,295
49,268
try a long, slow change from 1st to 2nd to see if its any better.
my pickup does the same if i change too fast.
other than that im at a loss.:Sad:
blackie
75
N IRELAND
C/CLASS
10 YEARS
Gear crunch
thanks for the reply..can get all gears and change down ok..problem only happens when pulling off from 1st to 2nd it crunches....
had the same problem in bessacarr e560. Gear linkage fiat replaced 1/2/3/4 gear linkage. Blackie
blackie
75
N IRELAND
C/CLASS
10 YEARS
Gear crunch
you are right,it only done it when starting of first to second.it happened to us in portugal,get it fixed now .take it to fait. Regards blackie
Pikey Pete
1,481
1,143
o
o
My '04 ducato has crunched between 1st and 2nd for a long time. I've noticed that when the gearbox is cold it isn't so bad. I've learned to live with it and change gear gently while double de-clutching.
If you do find a solution I would be interested, though I don't think it can be the linkage and is more likely to be the synchro mesh.
Pete:Cool:
Oscarmax
74
Coach
may 2008
Use synthetic gearbox oil, you will be suprised the difference it will make to the gear selection.:Smile:
peter t
154
Sunny Croydon.
Coach built
nearly a year.
Go for the easy option first, get your g-box oil changed... g-box oil works with syncro units to help speed em up and slow em down, syncro's/baulking rings don't work well without good oil... if it still does it get it into a garage... is it a year old model or have you owned it for a year. ???
Pete.
Peter JohnsCross MH
Jan 5, 2008
9,617
6,194
East Sussex
Autotrail
A year old van should not crunch, take it to your nearest Fiat service centre as it should still be under Fiat warranty.
Peter
S
Smudger 41
Thanks for all your replys the van is 53 plate we have had it a year..Blackie was it an expensive job to have done at the fiat garage Thanks for the email Let me know
peter t
154
Sunny Croydon.
Coach built
nearly a year.
Sorry forgot to ask ealier.... does reverse engage ok and hows the clutch feel. ?? no excessive travel / or high clutch pedal ?? it all helps.
pete.
S
Smudger 41
Reverse engages fine and the clutch feels fine no juddering ....
mpope13
Solihull
coach build
fiat ducato gear crunch
Hi I have this problem also. And mine does crunch when going in to reverse also.
it was fine when start up from cold but when coming off the motorway I struggle to get first anx second to engage at all not really a crunch for first and second but hard to select. Reverse is a hellova racket
any ideas
43,295
49,268
any ideas
that sounds like clutch adjustment.
Clutch not clearing properly or worn release bearing
