gaslow
Discussion in 'Motorhome Accessories' started by Welsh girl, Jun 16, 2014.
  1. Welsh girl
    Welsh girl Funster Life Member
    Nov 7, 2009
    2,679
    1,292
    living the dream.
    We have had 2 x6k gaslow bottles in our locker.
    With a manual changeover.
    How does that work.
    Do you turn one off to use the second or leave them both in the on position.
    How do you know when both are filled.
    We only had one bottle before we had the second one fitted so that was easy.
  2. ivorantony
    ivorantony Funster
    Jan 22, 2013
    490
    514
    London SE
    Leave one on and the other off, when you run out on first bottle turn second on on and start looking for LPG filling station, simples:thumb:
    Both should be turned off for filling until the automatic cut out triggers,
    I usually turn off the empty cylinder when turning on the full then both off for refilling,
  3. Welsh girl
    Nov 7, 2009
    2,679
    1,292
    living the dream.
    Then do you open the second bottle to allow filling then turn off again until 1st one is empty?
    With both turned off for filling then,do you then turn only one on when using the gas?
  4. Boater
    Boater Funster
    Oct 6, 2010
    56
    27
    Bridgend s.wales
    Turn both bottles off they fill through a separate pipe.
  5. Welsh girl
    Nov 7, 2009
    2,679
    1,292
    living the dream.
    Thanks for the advice.
    It wasn't explained to us when the fitter fitted it.
    We know gas should be turned off when filling but don't know when each bottle should be turned off or on.
