Gaslow
Discussion in 'Tech/Mech General' started by AdgeRas, Dec 15, 2009.
  1. AdgeRas
    AdgeRas Read Only Funster
    Sep 17, 2009
    495
    9
    Bristol
    First trip with the MH to Europe and I already think having Gaslow fitted may well be a good idea.
    I see that i can buy a good double bottle system for about £330, and it seems to suggest that you can fit it yourself. If you have got a good level of DIY, electrics, plumbing etc, is this something that is safe and sensible??
    Thanks Adge
    :Wink:
  2. hilldweller
    Dec 5, 2008
    27,554
    26,664
    Macclesfield
    It's as easy as changing a calor bottle.
    Apart from the filler. But put this in the locker and you don't have to carve a big hole in the side.
  3. Douglas
    Douglas Read Only Funster
    Aug 22, 2008
    2,837
    401
    South Wales,
    For a very little more you could buy a under chassis bulk tank, on aggregate its lighter, saves space, to my mind a much better use of your money.
    Doug...
  4. JJ
    JJ Funster
    May 1, 2008
    14,896
    26,717
    I have never regretted buying the Gaslow system (now fitted on both my vans.)
    I have had holes bored in my vans so the filler is on the outside of the vehicle. In practice these means the "stricter" filling stations don't have a problem with you, where as if you have a door open to fill up some (by no means all) cause difficulties.
    As I am very, very seasick I much prefer using the tunnel so would not, as Doug has, fit an underfloor tank as I have been told Eurotunnel don't allow you through with these tanks fitted.
    JJ
    What price convenience? ;-)
  5. Toffs-G
    Toffs-G Read Only Funster
    Sep 16, 2009
    606
    110
    West Sussex
    I have Gaslow bottles and think they are great, i have the filler in the cabinet.
    As for the point of Eurotunnel, it is only dual fuel vehicles they won't take, as I understand a gas tank (not for powering the vehicle) is permitted privided no more than 50kg of gas is in the tank.
    Hope this helps:thumb:
  6. JJ
    JJ Funster
    May 1, 2008
    14,896
    26,717
    Thanks Toffs-G for putting me right! Another Funster confirms what you say. I learn more each day!!!
    JJ
  7. keith
    keith Funster
    Aug 25, 2007
    3,286
    1,673
    Ecclefechan
    It's 80 % for fixed or Calor type bottles to a maximum of 47kg. See HERE
  8. AdgeRas
    Sep 17, 2009
    495
    9
    Bristol
    You can it seems have a 'fitted' tank if using the tunnel, but it must, like the bottles have the ability to be 'turned off' during transit through the tunnel. The following is the exact info from Eurotunnel.
    [​IMG]Allowed Gas Quantities
    Maximum allowed quantity ​
    Transport of gas containers to power domestic services* for caravans, campervans, vehicles fitted out as a campervan are restricted as outline below:
    - If your vehicle is fitted with a “mobile” gas container the quantity of gas is limited to 47kg (or approximately 93 liters) for a single container and is limited to 50kg (or approximately 99 liters) in the case of several containers.
    - If your vehicle is fitted with a “fixed” gas container the quantity of gas is limited to 47kg (or approximately 93 liters) for a single container and the maximum filling rate is 80% (or approximately 73 liters).
    In the case of several fixed containers the quantity of gas is limited to 50kg (or approximately 99 liters) on the whole with a maximum filling rate of 80% per container (or approximately 79 liters).
    - If your vehicle is fitted with a combination of mobile and fixed containers the quantity of gas is limited to 50kg and rules previously described applies.
    Nota: Containers must be easy of access by our staff for any check.
    This filling rate will be checked via the gauge. If no gauge is present, the vehicle will be refused.
    When travelling gas containers must be switched off and connection systems must be in good condition.
    Opening container tap or using domestic services are strictly forbidden until the unloading on the opposite terminal.
    *cooking, refrigeration, heating, water heaters...
    In case of non compliance with this conditions Eurotunnel reserves the right to cancel your journey.
