gaslow systems (1 Viewer)
dewaltman
157
49
south wales
a class
5 years , tugging for 27 years
Hi everyone I live near cardiff anyone know a good installer of gaslow in south wales or west country (m5 corridor) or do i need to wait for next round of shows for a good price
JJ
Mágica
May 1, 2008
19,253
47,964
Burstner Privilege T
over 50 years
You might like to try CMR... they travel around fitting Gaslow systems (08452602666)
JJ
(They fitted out both my vans...)
Landy lover
2,296
5,928
Zummerzet
27ft Eurolight
Camping Caravaning now 5'ering 49 years
Try these
Chelston Motorhomes
Chelston
Wellington
Somerset
TA21 9HS
01823 662075
They stock all Gaslow products have a massive workshops and an on site CL :thumb:
Not much more than hour and a half for you (Junc 26)
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Awesome avatar.
Plenty of people in here done it themselves. It's nearly as easy as changing a bottle. I mounted the filler in the locker rather than hack a hole through the side.
barryd
1,143
109
Yorkshire Dales
Since May 08
Here you go Link Removed
Shop around I did and prices for a full system fitted varied. I paid £250 for everything including a regulator with gauge, bottle and filler mounted on the side of the van. Took them about an hour. If your good at fitting stuff then as Brian said you can do it yourself. Im not confident enough so left it to the experts.
dewaltman
dewaltman
157
49
south wales
a class
gaslow
thanks everyone for information hidweller avatar was photographed at tewkesbury cc site the sky was fantastic that night especially with the abbey in the foreground,barryd if you dont mind who fitted the system for you
haganap
12,754
26,415
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
Try these
Dewaltman
Motorhome funster
near Wales.
really is a straight forward job for any nearly competent DIY man,,, after all I fitted mine myself.... Ive heard its so easy even familyguy Ediie could do it.:ROFLMAO:
barryd
1,143
109
Yorkshire Dales
Since May 08
No problem
A A CADMAN GAS SUPPLIES Fits & Sells Refillable Cylinders
17 FORGE YARD
CLEVELAND INDUSTRIAL ESTATE
ALBERT ROAD
DARLINGTON
CO DURHAM
DL1 2PJ
01325 363589
Probably a bit of a treck for you unless you happen to be travelling up this way for a trip in the van. Took them less than an hour. As the last poster said you could do it yourself but for me for £250 it was worth letting someone else do it. I might have a go at changing a tap but I wont mess around with Gas. Best of luck with it.
Barry
Douglas
2,835
400
South Wales,
6 years + 5 years in boat before that
Are you absolutly sure that you want to use Gaslow? For a few £s more you could buy a kit and fit a under chassis tank, and it may well be lighter that 2 large bottles.
Doug...
ingram
87
How do these things work, they are plastic and have no connection to the insde of the bottle?
Any ideas?
JK
There is a float inside the bottle: maybe there is a magnet which acts on another inside the gauge, similar to the system on some older Thetford cassette toilets for the level gauge.
I don't *know*, just an 'idea' as requested.:Smile:
Harvey
TonyIsh UK
120
Doug...
Any idea of costs (and possible problems) of fitting a chassis tank ? We have 20ft Rapido, and could do with the space gained for wet storage.
Rgds
joedenise
Isle of Sheppey
2 years
Gaslow
Doug...
Only problem with a tank is that when you change your motorhome you lose the tank and end up having to use Calor bottles again! Happened to us when we changed our van this summer. Planning of fitting Gaslow next year - once we've saved up enough!
Denise
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
Any idea of costs (and possible problems) of fitting a chassis tank ? Rgds
60L tank is £460.72 then theres brackets,piping,filler-I'm doing same and reckoning on around £600 -we think it'll be worth it for the extra storage and the amount of gas we'll have onboard.
Have a look at CAK site Link Removed
Link Removed
Mike
