GasLow Officiodos
Discussion in 'Motorhome Chat' started by mentaliss, Mar 25, 2014.
  1. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    Something strange :Eek!: after installing my single cylinder R67 kit and filling it up via the (fairly local service station)..pump meter confirmed 22.5 ltrs fill. We found to our astonishment that the gas was used up in ten days, of course there's no define science as too how much is going through the pipe only a gut feeling of previous experience using Calor gas
    ..previous trip before 'GasLow' was down through Europe through Italy into Sicily and back ..one and a half Calor gas,...... odd or am I being paranoid?
    PS have checked twice for external gas leaks.
  2. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,809
    1,876
    Warwickshire
    It's impossible to tell without knowing what your usage pattern was. We have 2 x 11 kg cylinders (old style, not R67) and that will last us about five weeks in summer. In very cold conditions, we have used one cylinder in three days.
    You say you are sure there is no leakage. How have you tested this?
  3. scotjimland
    Jul 25, 2007
    28,936
    25,589
    It's been a bit chilly of late.. were you using gas for space heating ?
    If so it guzzles it..
    As an example..
    A Truma Combi 6 heater uses between 160 - 480 grams per hour ..
    22lt = 11kg divided by 0.16 = 68 hours
    and divided by 0.48 = 23 hours continual use
  4. brynric
    brynric Funster
    Sep 5, 2009
    328
    310
    Worcestershire
    As with Jeanluc, it all depends on useage. In January this year on our way to Spain we used about 2litres each day in cold and miserable conditions as we travelled through France. As we reached warmer areas that dropped to about 2/3 litre each day. We rarely use hook-up so all heating and cooking is gas powered.
    It's the heating that uses the most gas, ours is the Trums C4002. One big advantage of the gaslow is that you know just how much you have used when you top it up. I'm usually pleasantly surprised how little we get through in the summer.
  5. Roryboys Dad
    Roryboys Dad Read Only Funster
    Mar 19, 2012
    631
    804
    Glapwell Derbyshire
    [FONT=Times New Roman, serif]Are you sure it is actually empty or is it just that useless stuck on plastic gauge showing empty?[/FONT]
    :france::france::france:
  6. mentaliss
    mentaliss
    Nov 2, 2012
    657
    307
    Lancing
    :Laughing::Laughing: is there a useless stuck on plastic guage on the R76 Bottle?..yep, definitely empty but now I know why I bought a refillable system theres a LPG station not far from here (Malaga):Laughing::thumb:
  7. emmitdb
    emmitdb Funster
    Aug 14, 2009
    1,717
    1,595
    Cornwall
    Greetings,
    We've just changed over from tugging and therefore we are still discovering a learning curve (Like the North face of the Eiger)
    We have a Hobby with what seems like a 747 jet engine under her bed that provides blown air heating and hot water. (I've ruled SWMBO out as both the source of the gas and heating:Rofl1:)
    Is that the same system being referred to (above) as Space Heating. Is it model specific as to whether it uses loads of gas or not.?
  8. Munchie
    Munchie Funster Life Member
    Jul 28, 2007
    8,571
    11,753
    Champagnac-La-Riviere
    Fridge also uses a lot of gas if not on hook up!!! :Smile:
  9. JeanLuc
    JeanLuc Funster
    Nov 17, 2008
    2,809
    1,876
    Warwickshire
    Yes, Space Heating is usually either blown air (normally Truma) or wet-filled radiator (normally Alde or some Truma systems too I believe).
