Gaslow in locker fill position (1 Viewer)
Jan 2, 2015
2,470
8,626
Cumbria
Burstner Solano t725
since 2014
Just busy fitting a 11kg gaslow bottle and have decided on an in locker fill point.
Would appreciate any comments on the suitability, as shown in image below, as to whether the LPG fill gun would fit on the fill point. I have never used a LPG fill gun before but I understand they are bulky?
Have taken all the inside/outside fill point advice and decided inside is how I want it.
As you can see, the locker door hinges fully up.
Aug 6, 2013
11,953
16,570
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
It'll work perfectly - the gun isn't bulky in any direction that will affect access. Bear in mind that because of the simplistic training given to filling station staff they might think you are attempting to fill a bottle as opposed to bottle-shaped tanks. Better on the outside of the van if possible.
Jul 13, 2008
3,738
3,855
Low profile
The nozzles lock on and can be quite heavy, I had mine screwed onto the lock floor before I moved it outside.
Sep 3, 2012
7,551
26,056
Cheshire
C Class Elddis 175
8+ years
Some guns have a handle that turn 90 degrees to lock on. The top hung door may be in the way. If there is no where else to put it. Best would be in the middle of the locker top as suggested any from the sidewall, but as close to the outside as possible with the locker door shut.
