Gaslow - how long to fit?
Discussion in 'Motorhome Chat' started by maz, Feb 14, 2011.
  1. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    Does anyone know what is a reasonable time to fit a new Gaslow system professionally? Would be looking at 2x11kg cylinders, regulator, outside filler point, auto-changeover valve, stainless steel hoses?
  2. Brisey
    Brisey Funster Life Member
    Sep 4, 2007
    6,564
    7,649
    Tropical Bar,Benidorm.
    Hi Maz
    I would think that the job could be done in 2-3 hours assuming there are no unexpected problems.
    Brisey
  3. JJ
    JJ Funster
    May 1, 2008
    14,648
    25,990
    CMR fitted the same equipment to my Hymer and it was done in a rally field in well under an hour...
    JJ
    PS... I found the automatic change over valve a really bad thing as the one and only time in over thirty years of motorhoming I have run out of gas was with this... I hadn't realised it had "kicked in" and I was left with no gas! (Luckily a refill place was less than a mile away...
  4. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    Generally takes me around 1 hour to fit a Gaslow system , also have to perform a gas soundness check before commencing any work then check once completed for any leaks in the system
    Mark
  5. niggle
    niggle Banned - Rule 1
    Aug 5, 2010
    806
    607
    SOUTH AND FRANCE
    gas low will do it while you wait in yatley,it takes 1 hr and they also gige you a cert that you now need in france to say it is fitted propley like corgi exept lpg
  6. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    Ring Gaslow - they'll tell you.
    Apart from that, it all depends on the make and model of motorhome - some are considerably more difficult than others to fit an external filler.
    Although you didn't ask, if it was me I wouldn't have the auto-change valve. You lose all sense of how much gas you've used - much better keeping one cylinder closed until you run out and then switch over to the other - that way you'll know you're half way through your supply and have a better handle on how soon you need to fill up again. I've also the Gaslow guage fitted inside of the van, but that's a waste of money too, for the same reason. It does no more than tell you when you're about to run out, and your hobs can do that!
  7. Squire
    Dec 30, 2010
    324
    60
    Apart from that, it all depends on the make and model of motorhome - some are considerably more difficult than others to fit an external filler, and that's what will take as much time as the rest of the fitting.
    Although you didn't ask, if it was me I wouldn't have the auto-change valve. You lose all sense of how much gas you've used - much better keeping one cylinder closed until you run out and then switch over to the other - that way you'll know you're half way through your supply and have a better handle on how soon you need to fill up again. I've also the Gaslow gauge fitted inside of the van, but that's a waste of money too, for the same reason. It does no more than tell you when you're about to run out, and your hobs can do that!
  8. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    Thank you - will send you a PM. :Smile:
  9. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    I was thinking more about not running out of gas for the heating overnight.
  10. Wildman
    Wildman Read Only Funster
    May 30, 2008
    15,458
    8,602
    Ilfracombe, Devon
    do you really need heating on over night, once in bed sufficient covers will keep you warm.
  11. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    Well, I certainly planned on keeping it on low overnight in winter to stop any problems with pipes/tanks freezing up ......
  12. JJ
    JJ Funster
    May 1, 2008
    14,648
    25,990
    I am with you on this one Maz... I am a "heater on at night" person... I have been able to move on from the days when I woke up with ice on the top of my duvet!
    If the Wagon was cold in the morning I would never get out of my pit! :Rofl1:
    As long as you are an organised person the auto switchover will be great in the overnight heat situation... sadly I am not (but I can switch over from one bottle to the other without getting out of the Wagon)
    JJ
  13. haganap
    haganap Funster Life Member
    Dec 5, 2007
    11,130
    13,880
    Heavan
    We would most certainly when skiing or touring the cold Scottish highlands leave the heating on over night.
    As Mark say's (CLS) doesn't generally take long to fit.
    Don't know what certificate that Niggle is talking about you needing when going to France? like to see some one turn some light on that one? I have never had one and TBH never knew I did?
  14. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,552
    3,361
    Telford, Shropshire
    Depends on the particular installation in question but I generally allow an hour to complete.
    D.
  15. Squire
    Dec 30, 2010
    324
    60
    Hmm - I would say you've hit on the one arguable reason, although you'll still have the problem of running out during the night, only it'll take twice as long ! And then you'll have no 'back-up'. Everyone to their own, but on balance I think I would still prefer my method even if it meant waking up to a cold van on one morning, not that I'd normally keep the heating on overnight anyway. But then again, I don't normally go anywhere where it's colder than Scotland. And when I'm touring somewhere like Scotland I always take the opportunity to top up the LPG at the same time as taking on diesel whenever I can, whether I feel I need to or not.
  16. maz
    maz Funster
    Jan 26, 2011
    2,530
    2,170
    Out there somewhere
    Don't know about French certificate requirements, but when I mentioned to the insurance company about possibly installing Gaslow they said fine as long as it was professionally installed and I was given a certificate by the installer.
    Exactly how I'd intend using the system. :Smile:
  17. Lynn ( Mrs Ash )
    Lynn ( Mrs Ash ) Read Only Funster
    Aug 16, 2010
    259
    71
    (The Midlands) Nuneaton
  18. haganap
    Dec 5, 2007
    11,130
    13,880
    Heavan
  19. Lynn ( Mrs Ash )
    Aug 16, 2010
    259
    71
  20. C.L.S
    Jul 22, 2007
    410
    49
    When installing Gaslow or any other refillable system , all the work takes place before the regulator so there is no interuption to pipework etc..... A certificate is NOT required for this type of work as no modification to the pipework has taken place. A certificate of conformity relating to the bottles is available or a gas soundness certificate can be issued once installation is complete.
    Mark
