Gaslow hoses
Discussion in 'Motorhome Accessories' started by iandsm, Feb 19, 2014.
  1. iandsm
    iandsm Funster
    Jan 3, 2008
    1,575
    2,739
    Suffolk
    I have just fitted two new Gaslow hoses from the cylinders to the regulator. I noticed that what look like a crimped collar on each end of the hoses where the metal parts meet the plastic outer casing, near the connecting nuts are fairly free to wiggle about although they cannot be moved up along the hose itself. I have tested for gas tightness and there are no leaks. I suspect the crimped collars are there to stop the hose being over kinked as it enters the fitting.
    The same crimped collars on the filler hose and the hose connecting the two bottles are the old style, fitted about three years ago, with brass nuts and the collars on those are solidly fixed. I was just wondering if this slight movement on the new chrome finish connectors is usual.
    Anyone noticed similar?
  2. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,107
    14,921
    Leeds the one up North
    Yes it's normal but varies from hose to hose. It just retaines the outer braided sheath.
    • Like Like x 1
  3. iandsm
    iandsm Funster
    Jan 3, 2008
    1,575
    2,739
    Suffolk
    Gas low
    Much obliged, thanks.
  4. spongy
    spongy Read Only Funster
    Jul 29, 2009
    266
    89
    hampshire
    Do you have the secumotion system on your rapido, when I changed the hoses on mine for gaslow stainless steel hoses I could'nt retain the fittings on the original hoses as they were not compatable with the new fittings. I would be interested to know if you were able to get round this as I would have liked to keep the secumotion system.
    spongy
  5. iandsm
    iandsm Funster
    Jan 3, 2008
    1,575
    2,739
    Suffolk
    Gaslow
    I did have the Truma butane hoses with the green cut off button for secumotion attached to my Gaslow cylinders which I liked. They are the only hoses that comply with some EU directive on having the gas on when travelling which we do. But they had come to their use by date and needed to be replaced. I thought long and hard about whether to replace them with the same Truma Secumotion or go to Gaslow steel.
    I decided on Gaslow steel because the Truma regulator has a green secumotion button so in the event of an accident anything downstream of that would be cut off automatically. The only non secumotion protected piece is the Gaslow hose between the bottle and the regulator. I figure that if we had an impact strong enough to detach the Gaslow hose from the bottle or regulator, it would be catastrophic and we would be past caring anyway. Further the Truma hoses have a life of 5 years whereas Gaslow is 25 years.
    If I leave the gas on when travelling I am aware I would probably breach the EU directive, but I can live with that, "Opps sorry officer I forgot to turn them off" The `truma part number is 50410-06 should you go that route, about £36 each I think.
  6. spongy
    Jul 29, 2009
    266
    89
    hampshire
    Thanks IANDSM
    Thats about what I thought, my rubber hoses were 5 years old which is why I replaced them, in fact when I took them off they were in quite poor condition. I shall probally continue turning my gas off, when I remember! same as disconnecting the hook up lead, when I remember!
    Thanks for your help
    spongy
  7. micky drip
    micky drip Read Only Funster
    Jul 4, 2012
    190
    121
    mid wales
    My Lunar has a Secumotion regulator.Is this prone to failure? Should I carry a spare? What do I need in order to use French bottles?
  8. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,374
    9,820
    yes, the truma secumotion is prone to frequent premature failure, its a design flaw. i say that because regulators from gok or gasit dont fail the same way. my prefference would be to carry a spare known to be reliable. sadly though youre not likely to find a secumotion equivalent, but i dont know too many that use the system as designed. great news is that other non truma regulators cost a fraction the price
    for french or spanish bottles, just pick up the appropriate high pressure pigtail that screws onto the regulator and bottle. that way you can pick a suitable cylinder up at the supermarket and fit the appropriate pigtail. no need to carry extra gas bottles. when empty exchange for another full one or another type. in practice theres only 3 or 4 pigtails you need to carry for extended touring.
  9. Sidney
    Sidney Funster
    Jan 27, 2013
    1,175
    749
    Stamford
    I bought this converter from GasIt.co.uk and was able to use the existing pigtail with green button thing
    • Like Like x 1
