SOLD Gaslow filler point (1 Viewer)
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Looking for a Gaslow white external filler point, I have the bottle and pipes just need the filler point which will be external to the gas locker.
Sep 25, 2009
793
1,386
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Give Autogas at thirsk a ring.I am sure they will be able to sort you out.or type Gaslow on web you should get some results
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Thanks for the inks I have seen these before I was just seeing if anyone had a second hand one a bit cheaper
Minxy
32,646
66,526
E Yorks
Carthago Compactline
You can buy them without the pipe if you want:
Minxy
32,646
66,526
E Yorks
You can get just the housing too if you wanted to remove your existing one and put this in its place, or just remove the bayonet from it to put inside this on your new van (assuming you've still got your old MH) or buy the bayonet bit to go with it but that'll probably work out dearer than the one I posted above.
http://leisurelines.net/gas-lpg-fill-point-housing-recessed-70mm--cap---white-3975-p.asp
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
I do not have anything apart from the bottle and pipes looking for one that someone has laying around not being used and yes cheaper than what all the above links show. If nothing comes up I will buy new.
Neckender
3,221
5,921
Neckend or North Wales.
VW T6.1Kombi day Van
Since 2004
I have a white one second hand and a black one brand new are you going to Peterborough show.
John.
ES Cumbrian
ES Cumbrian
321
143
Cumbria
Autotrail
3 years
Not going to the show in fact not going anywhere for the next few weeks as moving house soon so will be in Scarborough all the time. Could you pm me the price for each and will try to arrange something.
