Gaslow filler point, in or out?
Discussion in 'Motorhome Accessories' started by The truck, Apr 6, 2014.
  1. The truck
    The truck Read Only Funster
    Mar 28, 2014
    5
    Lee on Solent
    Having researched installing a gaslow system, the next question is where to fit the filler point. Gaslow point out that if you need to open the gas locker door to fill the system you may be refused especially in France. It's clearly less destructive to the bodywork of the motorhome but I wonder if this will be a measure that proves to make it less practical. What is the experience of filling these systems where the filler point is within the gas locker? Thanks for your help.
  2. icantremember
    icantremember Funster
    Sep 2, 2010
    5,383
    7,488
    Nr Watton in Norfolk
    Have the filler point put into the lower cill if possible ..... this will rule out any possible damp problems.
    • Like it Like it x 1
  3. JJ
    JJ Funster
    May 1, 2008
    14,871
    26,669
    IMO definitely OUT...
    And make sure it is fitted to a sturdy bit of bodywork as the LPG gun and hose pipe can be heavy bits of kit.
    JJ :Cool:
    • Like it Like it x 2
  4. chaser
    chaser Funster
    Feb 16, 2013
    7,700
    8,763
    uttoxeter
    It is up to you , but whatever you decide , have a look at gasit before you buy , lot cheaper for identical kit:thumb:
  5. lunarman
    lunarman Funster Life Member
    Sep 23, 2008
    1,481
    888
    South Glos
    I was not happy cutting a hole nearly 3" diameter in the side of my van so I opted for a different type of filler point . It is fitted in the fairing around the wheel arch. (its the small black square in the picture).
    It also has the advantage that if I ever change the van or want to sell the fillable system the only thing that is left is a hole about 1" diameter that can be filled with a grommett.
    Lunarman
  6. trophychap
    trophychap Funster
    Dec 24, 2009
    730
    5,691
    bedworth warks
    Ours is inside the locker never had problems filling, have had the odd attendant come and look but never been refused here or abroad.
  7. jb0371
    jb0371 Funster
    Jul 8, 2011
    462
    402
    Norfolk
    gasit is def the way to go, very helpful guys on the phone, next day delivery and a lot cheaper than gaslow for the same thing apart from the colour of the bottle. I put my filkler point on the outside, mainly because my door hinges upwards so could be a pain in trying to fill it up, also i am lazy, I just want to pop the cap and fill up.
    If you do put the point on the outside then another tip is to place the filler pipe into another piece of tubing so as to protect the pipe from chaffing as it works it way through the bodywork to the bottle. A piece of 38mm waste water pipe works for this (measure the gas pipe first just to make sure).
  8. Puddleduck
    Puddleduck Funster
    Jan 15, 2014
    6,704
    14,423
    Scottish Borders
    If you have a certificate from the manufacturer / installer to say that the system complies with any regulations would it make any difference? I can see that an outside filler would possibly be easier (not having to open the locker) but more subject to being tampered with? I've no idea really but we will be getting a refillable system so I'm interested in the answers. OH thinks outside and I don't know!
  9. iandsm
    iandsm Funster
    Jan 3, 2008
    1,672
    2,815
    Suffolk
    In or out
    Remember that you MUST turn off the cylinders valves before fulling, given that they are inside the locker, unless you turn them off before your journey you will have to open the locker anyway.
  10. Wombles
    Wombles Funster
    Oct 28, 2013
    2,585
    1,886
    SW England
    Having read the posts on here about possible problems with some fuel stations if the filler point is inside, we wanted to have an external point but it wasn't viable so it is now inside the locker. Hopefully any problems will be rare as refillable bottles are becoming more common now. On the plus side the filler point is behind a locked door whereas a Gaslow external point does not have a locking cap. Don't know if any are suitably sized locking caps available or if this is really an issue for anyone but thought I would mention it just in case it helps anyone.
  11. chaser
    chaser Funster
    Feb 16, 2013
    7,700
    8,763
    uttoxeter
    Mines inside, no problems yet. Hth:thumb:
  12. Wombles
    Wombles Funster
    Oct 28, 2013
    2,585
    1,886
    SW England
    Fitting an external point may not be viable on your Chausson as it wasn't on ours - had Vanbitz fit ours (Funster discount:Smile:) so trust their experienced judgement that inside was the only safe & practical option.
  13. trophychap
    trophychap Funster
    Dec 24, 2009
    730
    5,691
    bedworth warks
    Err, bearing in mind your filler point is supposed to be higher than the bottles - I wouldn't want one in the van 'skirt'. This is supposedly to prevent LPG from puddling in the pipe - so it runs down into the receptacle you are filling not sure how that's supposed to work frankly. But Gaslow's fitting instructions tell you this - also tells you not to have sags in your pipe because of puddling.
    I seem to remember reading somewhere that it doesn't make any difference if your bottles are open or closed when you fill them.
  14. The truck
    Mar 28, 2014
    5
    Lee on Solent
    Gasit
    Well thanks to all for opening my eyes to the gasit options. Having read a different thread I am quite interested in the single Gasit refillable option with an internal locker fill point. Gas it claims that this conforms to all UK and EU regulations. I hope they are able to supply certificates to verify this and that this would be enough to satisfy forecourt attendants both here and abroad.
    Gas it are currently quoting £147 for a single 6 kg cylinder plus internal fill point. This seems like a good starting point as the system can be added to later on.
    All their other accessories such as auto changeover also seem much cheaper than the gaslow alternatives.
  15. chaser
    chaser Funster
    Feb 16, 2013
    7,700
    8,763
    uttoxeter
    That's the one I have, ordered it 12 o clock one day parcel man knocking on door at eight next morning , all fitted and filled by two o clock:thumb:
  16. ShiftZZ
    ShiftZZ Funster Life Member
    Feb 19, 2008
    19,812
    36,113
    Leicestershire
    On the Rapido, it's inside the cabinet. Just make sure that you have it in the right position, too far back and you may not be able to connect to the filler hose.. This happen to me, the person fitting it put it so far back that it was virtually impossible to use, and the same person used 4 different type of screws to hols the bracket in place. One was even a wood screw and different types of screw heads.
    Thank goodness Venture Caravans, a thoroughly professional organization sorted the amateurish mess out..
    Used it in France and the UK, never had a problem...:thumb:
  17. iandsm
    iandsm Funster
    Jan 3, 2008
    1,672
    2,815
    Suffolk
    Gas
    You are right about puddling but my Gaslow instructions clearly state highlighted in red,
    "Important Always turn off cylinder valves BEFORE filling"
    I doubt they would have this warning if it made no difference.
  18. chaser
    chaser Funster
    Feb 16, 2013
    7,700
    8,763
    uttoxeter
    This is mine, never heard of this puddling thing though, new one to me , mines uphill , no probs I can see, as you will see , still got one calor bottle in as well so if I can't find one , maybe find the other:thumb::thumb:
    Obviously not on it's side:Doh::Doh:
  19. Nick100
    Nick100 Read Only Funster
    Apr 6, 2014
    23
    48
    Blaenpennal
    Filler point
    I put mine outside under the rear bumper it is protected by the towbar from being bashed or bottoming out. Inside fitting bothered me as there seemed concerns that any leakage may not be able to escape from inside the van.
  20. Phill D
    Phill D Read Only Funster
    Dec 6, 2011
    4,414
    4,633
    South Wales
    i was exactly the same and fitted the same filler from GASIt at a fraction of the Gaslow price and was so easy to find a suitable and strong enough place.
