gasit (1 Viewer)
Jul 10, 2016
413
385
hucknall
Swift bolero 712sb
10 years
hi , looking for an installer in the nottingham ish area, any ideas ?
kip
633
482
Bulphan
Have you not thought of doing it yourself ?I u tubed a video that showed you in easy clear steps what you need & how to install.Believe me i`m average joe when it comes to D.I.Y,but found it pretty straight forward.I put the refill valve on the outside skirt which was probably the scariest part.Did all the safety checks afterwards All ok.:)I ordered everything direct from gasit over the phone.The lads at gasit were very helpful.Give em a call.Oh yeah saved myself about £300.:eek:(price quoted by cranham caravans).
Bart
3,188
1,397
Northern Ireland
Boxer L4H2 van build
Since 2016
Seriously do it yourself , its very easy , the hardest part is taking your time to be sure you are gonna drill / cut the hole in the right place for the Gas filler.
Feb 13, 2013
991
1,082
Edinburgh
Rapido 881F
Since 2015
or consider Auto2000 - I found the cost difference for the new 4 valve bottles to be marginal and there was no way I was cutting holes in a new van! If your van has payload challenges they also do aluminum bottles, which we have, and to date they have been excellent. You can also stay over if you need to. Worth getting a quote a least. I don't work them and am not on commission!
http://www.autogasleisure.co.uk/services.html
Feb 24, 2013
13,035
101,352
Bolsover, Derbyshire
Hymer S800
not long enough
don't let them bully you, what's easy for one is a nightmare for others and would be for me too o_O
if not the fitting, which I do agree is not much more than changing a standard cylinder, but the fact that gas pipework, if not fitted properly the end result is not a pretty concept, then the hole in the side to drill, no thanks
I used Automate for satellite and solar panel, they also do Gaslow systems
http://www.automateuk.com/
not sure if you already have the bits, but they might still fit anyway, they did a great job on my MH (y)
Theonlysue
6,104
7,383
Essex
As Executive 50th an
Not long enough!
Used autogas2000.
Do it once and do it properly.
They have all the cylinders there to choose from including 14kg aluminum and underslung tanks.
Do it wrong and it's very dangerous
May 22, 2015
1,424
2,587
Wem Shropshire
Carthago E Line 51QB
Been getting away since 2008
DIY...........Don't Involve Yourself
Seriously though it's real easy to do and you'll save yourself a few quid.
cookie
Jul 10, 2016
413
385
hucknall
Swift bolero 712sb
10 years
thanks , done it on another van with no problems , just thought i would be idle on this van
Jaws
23,827
72,276
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Alugas2000 ... they will supply your bits, help as much as you need on the fone, AND you get a Funster discount too !
In fact I have only just got off the fone from Chris as I am about to change up to a twin bottle system ( and looking at an underslung tank as well ! )
Emmit
8,024
17,697
Cornwall
Pilote Explorateur
Jan.2014
I 'Bottled it' when it came to drilling a hole in the 'van. SWMBO wouldn't let me.
However, I farmed out the drilling and connecting to a firm in Plympton (Nr Plymouth)(Tamar Towing Centre) and they charged the magnificent sum of £43+pennies for doing the dastardly deed.
They even threw in a comfy seat and a cup of coffee while I waited for them to complete the task.
