Gas Vent for Gas Bottle Locker - CO Vent
Discussion in 'Tech/Mech General' started by zen navigator, May 5, 2010.
  1. zen navigator
    zen navigator Read Only Funster
    Mar 27, 2009
    111
    Manchester
    I looking for a new vent on my Gas Bottle Locker for my Benimar Europe 6000 ST
    The logo on the vent says CO Vent - Air 170 cm2.
    The dimensions are 37 cm x 14cm.
    Any one sourced one of these vents?
    Dave
  2. Phil
    Phil Read Only Funster
    Oct 21, 2007
    226
    Herts
    How does the Carbon Monoxide get into your gas Locker?
    Phil.
  3. zen navigator
    Mar 27, 2009
    111
    Manchester
    I should clarify it is not a CO vent\filter\detector etc.
    It is branded as CO Vent - Air 170cm2. Which are\were the manufacturers of this said item. Hence the post.
    Its a standard vent like MKP\Electrolux etc.
    Dave
  4. Phil
    Oct 21, 2007
    226
    Herts
    The door vents are usually sold by most caravan accessory shops.
    The vent for gas should be in the floor, mine is a circular one about 2 inches diameter with a metal grille over it, to stop mice I guess.
    There are similar floor vents near the water heater and at the back of the fridge.
    Phil.
  5. zen navigator
    Mar 27, 2009
    111
    Manchester
    My vents are on the top and bottom of the door and I can't find the size on ebay or any of the web stores. Hence the post.
    I think the post title was a tad misleading as CO Vent is the branding not the function.
    Push comes to shove, I have to source an alternative and swop both vents.
    Thanks for your replies.
    Its 37 cm x 14cm and is branded as CO Vent - Air 170 cm2 with 4 screw holes one in each corner.
    Anyone sourced this vent or a similar sized vent?
  6. Phil
    Oct 21, 2007
    226
    Herts
    My Fridge Vents are 37 x 14 so maybe they used those? Or they might fit anyway. The aperture is about 35 x 13, but without breaking the seal and taking them out I can't be certain.
    Phil.
  7. zen navigator
    Mar 27, 2009
    111
    Manchester
    Sounds promising.
    I dont suppose you know the make model of the vent? Failing that, I guess, I just keep looking and I find one on the web or at a local stockist.
    Thanks for your time
    Dave
  8. Phil
    Oct 21, 2007
    226
    Herts
    My fridge is an Electrolux, so it is possible they supply the vents, worth a Google.
    Phil.
  9. zen navigator
    Mar 27, 2009
    111
    Manchester
    Seen many electrolux vents on the web, but none of those dimensions.
    Sure something will turn up soon.
    Thanks for yer time.
  10. TonyIsh UK
    TonyIsh UK Read Only Funster
    Oct 31, 2008
    120
    Tried o'leary or cak sites for spares ?
    rgds
  11. zen navigator
    Mar 27, 2009
    111
    Manchester
    tried o leary already...no joy
    What is cak :Eek!: Where I come from I wouldn't use it as a vent :Eeek:
