Gas Usage ? (1 Viewer)
Oct 1, 2013
7,511
19,937
Lanzarote
Nil by mouth
Lots
T'other day me mates fixed a problem with the Dometic 3 way fridge so that it can run on gas :)
But it seems to have used rather a lot since ???
I've had the fridge on gas for 3 days.
Last night was cold here so we had gas heating on all night. It's a Heatsource HS2000 jobby.
Up to that we had 2/3 full propane 6.5 Kg bottle. It's now empty :(
Should that little usage use about 4-5 Kgs ?
Answers on a postcard please. Or type here if easier
Aug 18, 2014
23,772
133,556
Lorca,Murcia,Spain
Transit PVC
16 years since restarting
The heating will consume that amount overnight I'd have thought.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
Ours is pretty insignificant. Looking at the flame it's only like a gas cigarette lighter.
Now the heater is altogether different.
Yorick
Oct 1, 2013
7,511
19,937
Lanzarote
Nil by mouth
Lots
Aha, so it looks like the heater was the culprit :(
It was on for 12 hours.
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
Vans and tugs since mid 70's
been there done that, you need to secure the gas hose at both ends with proper hose clamps.
Munchie
8,921
12,581
Camping Les Vigeres
Font VendĂ´me
Since 2004
Heating and fridge will chomp gas like it was going out of fashion!!!
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
This is where refillable systems payback when gas is used as the primary heat source. 59.7ppl at Asda :xThumb:
So 5 kilos of LPG (10 litres)for around ÂŁ6 instead of around ÂŁ20? got to look into this, possibly at a tank that will go into the existing 2 bottle storage locker as there's little room elsewhere.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
Jul 5, 2013
11,723
13,702
Since 2013
You can buy refillable bottles to use instead of calor bottles and fit in the existing bottle store. Look for gasit or Gaslow. I have gasit and it only took a couple of hours to fit including the filler etc. Much easier than fitting a fixed tank, which are usually designed to be underslung to the chassis
Feb 8, 2014
1,662
4,673
Sheffield
Eldis Majestic 115
thanks Andy and Peter, looking at costs of a fitted tank against double bottle systems and filling availability abroad.
Techno
Jul 28, 2010
15,475
20,756
May 2010
ÂŁ340 for twin 11kg bottle kit delivered. variable depending on required length of fill hose.
Jaws
23,836
72,461
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Bugger,, did not see the bit where you had the heating on all night.. Thought you had turned it on and it had died soon after.
We was at a Funster Valentines day meet a few years ago.. Did the same ( you soon learn LOL !! ) and emptied two bottle in two days !
Jul 5, 2013
11,723
13,702
Since 2013
I have single 11kg bottle and a filler inside the locker, all from Gasit. I use a calor as a spare in case I ever run out. Cost me ÂŁ189, including adaptors for all of Europe and was delivered in less than 24 hours.
200
200
North Hants
Chatsworth CV40
Motorhome since 1997 Camping since 1990
I would advise bottles rather than a tank as the installation can be moved & re-installed in a replacement van in the future. Not so easy with a tank.
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
After a few years of never needing the spare, it now lives at home and the space is used for the Cadac.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Single 11kg "Gas-it" bottle does us.. Fill up whenever you see LPG/GPL sign !! And room for the Cadac beside it !! Loverly.
davejen
1,861
1,235
Preston
Given up travelling
Since 1992
Unless your name is ANDY (techno100)!
Cheers, Dave(n)
