Gas tank gauge
Discussion in 'Motorhome Chat' started by nigglynelly, Aug 31, 2011.
  1. nigglynelly
    nigglynelly Funster
    Jul 31, 2009
    73
    15
    Warwickshire
    I have no way of knowing how much gas is left in my propane cylinder so I would like to fit a gauge.
    Does this have to be done by a specialst and what are the best gauges to use?
  2. scotjimland
    Jul 25, 2007
    28,976
    25,674
    Presumably you are talking about an underslung LPG tank ?
    If so, does it have a spare blanked outlet on the top? If so you should be able to fit one .. contact an LPG tank supplier.
    if not.. it's a specialist job .. the tank would have to be removed to have it fitted then re certified..
  3. nigglynelly
    nigglynelly Funster
    Jul 31, 2009
    73
    15
    Warwickshire
    I have a locker that has the space for two 11kg Propane tanks. Not sure about the connector.
  4. scotjimland
    Jul 25, 2007
    28,976
    25,674
    you are talking about propane bottles... ?
    There is no reliable way of knowing how much gas is in a propane bottle other than weighing it ...
  5. Snowbird
    Snowbird Funster Life Member
    Apr 24, 2009
    10,320
    17,030
    Liverpool.
    I had a similar problem on the LPG tank on my VW until I got underneath and saw a plate with a big black knob on it.After unscrewing the knob the plate came off and there was a small gauge behind it.OK its not electric and I cant see it from inside the van,but its there. Most LPG tanks have this as well as a electric one inside.
  6. nigglynelly
    nigglynelly Funster
    Jul 31, 2009
    73
    15
    Warwickshire
    Yes. Sorry for the incorrect terminology:Blush:
  7. Geo
    Geo Trader - Funster
    Jul 29, 2007
    9,846
    6,096
    Mansfield,Notts
    You can exchange your Calor bottles for the new lightweight ones at any Calor supplier
    they have built in gauges on each cylinder:thumb:
    they are only a £ or two dearer for the first exchange
    Geo
  8. scotjimland
    Jul 25, 2007
    28,976
    25,674
    Just to clarify
    Calor Lite does have a pressure gauge.. but it only tells you when your running low.. it is not a level indicator.
    there is also an ongoing premium to pay each time you exchange
    list price for 6kg propane is £19.99
    list price for 6kg propane Lite is £25.99
  9. DBSilverfox
    DBSilverfox Read Only Funster
    May 13, 2010
    592
    98
    Nottingham
    As an alternative you can buy a gauge from the Gaslow range like i did. It just fits between the propane cylinder (does not have to be a Gaslow cylinder, don't worry) and the pigtail, easy to fit. Can't remember the price but I got mine from Brownhills last year
    David
  10. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,498
    1,355
    SW Northumberland
    • Like it Like it x 1
  11. scotjimland
    Jul 25, 2007
    28,976
    25,674
    These are cheap and a waste of time.. it only displays the level when you are using a significant amount of gas which generates a temperature difference between the liquid and gas in the bottle... you can often see this when frost gathers on the lower half of the bottle.
    A pressure gauge is also a waste of money.. it only indicates when the bottle pressure drops.. ie .. nearly empty.. you know this without a gauge.. the cooker flame goes low.
    The time honoured method:
    You have two bottles, when one runs out you change over and have the other replaced ASAP . .. simples.
    Nor do I like Auto change-over valves.. you could end up with TWO empty bottles.. and sods law says this will happen on a bank holiday or late at night when everywhere is closed..
    • Like it Like it x 2
  12. Stewart J
    Stewart J Funster
    Jul 1, 2010
    1,498
    1,355
    SW Northumberland
  13. Squire
    Squire Read Only Funster
    Dec 30, 2010
    324
    60
    'Time honoured method' Now THAT is good advice from someone who's got many years motorhoming under his belt. Spot on and totally accurate, right down to the auto change-over valves ... And what's more - it's the cheapest solution as well as the best :thumb:
  14. nigglynelly
    nigglynelly Funster
    Jul 31, 2009
    73
    15
    Warwickshire
    Thanks for all the advice. I will get a second bottle.:thumb:
  15. Squire
    Dec 30, 2010
    324
    60
    Sorry Dave but that's useless for what the OP wants. A Gaslow gauge is not a CONTENT gauge but a PRESSURE gauge, and the gas pressure within the bottle remains virtually constant until the bottle is nearly empty. It only tells you that you're low on gas as you actually run out! Not, say, that you have 'half a tank' left, or 'three quarters' or whatever.
  16. DBSilverfox
    May 13, 2010
    592
    98
    Nottingham
    Hmm, anyone want to buy a Gaslow gauge? :cry: Guess I should add that to the list of things that seemed a good idea at the time
  17. Squire
    Dec 30, 2010
    324
    60
    You're not alone, Dave - I too thought it a good idea at the time and as a result I too have a surplus Gaslow gauge for sale :RollEyes: That's how I came to know ! I never did buy an automatic change-over valve as otherwise that would be for sale, too :Smile: But I DO swear by the Gaslow system and wouldn't be without it. I can't imagine going back to the old heave-a-bottle-about Calor system ....
  18. WynandJean
    WynandJean Funster
    Mar 23, 2010
    2,689
    1,489
    West Midlands
