gas system problem
Discussion in 'Tech/Mech General' started by chrisboyo, Feb 10, 2015.
  1. chrisboyo
    chrisboyo Funster
    Aug 5, 2009
    1,338
    825
    Newport South Wales
    We are currently on Villa Sol and have a problem with our gas supply
    We have a fixed under slung gas tank and have been feeding gas in through to BBQ point for the past week
    I have of course turned off the tank supply prior to doing this
    Our gas supply has got less over the past few days and is now stopped all together,
    I have unhooked the supply to the BBQ point and turned on the fixed tank supply witch was filled prior to going on site ,but no joy
    Got an engineer booked but he is not able to attend until Thurs/Friday
    Any ideas ?
  2. mitzimad
    mitzimad Funster
    Jan 28, 2008
    3,129
    3,528
    walthamstow east london
    can only think something is blocked somewhere cant be regulator as youve tried two different ones does it affect everything? is there a valve that would have been in circuit for both manifold maybe
  3. Wickolad
    Wickolad Funster
    Sep 10, 2013
    480
    519
    Wickersley
    Is there any gas in your underslung tank? I know you said it was filled prior to trip but could there be a leak somewhere that has drained the tanks and thus reduced pressure due to escape, combined with a possible duff regulator or two. Where are you getting your gas if you fill a bottle and onboard tank before trip or pitching. Could it be dirty shite gas? Just a thought :)
  4. TerryL
    TerryL Funster
    Mar 5, 2010
    1,403
    1,385
    North East
    Just a thought, might be completely off track. Is your external supply through the BBQ point regulated? I have in mind back pressure causing a problem somewhere, maybe the regulator.
  5. tonyidle
    tonyidle Funster
    Aug 6, 2013
    3,085
    2,926
    Kendal, Cumbria
    It does sound like a blockage - probably the clue is where you said it got less and less over a period of time. What casts doubt on that theory is that you have used two different supply points so they can't both have blocked. The common point is the manifold of shut-off taps for your appliances: is it possible one or more could have been moved towards off? It might be worth closing them all then re-opening them.
