Gas querey (1 Viewer)
merlster
7
kent
talbot express
about 6 years
:reel:Hi all.I have just removed the paloma water heater from my Talbot express.It started leaking and I just want rid.The same goes for the riviera monaco gas heater.No leak on this.It just did not want to work.All I would like to know is,how do I close off the gas pipes,that where attached to the afore mentioned appliances.Any help would be appreciated.Thanks
wivvy's dad
3,205
1,795
48.066895,12.862673
Transit LWB Hi-Top PVC
On and Off since '98
Quick and dirty way is to bend over the last 2 inches, back on itself.
Someone will be along shortly to tell you that is illegal.
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
hi you could visit a good plumbers merchant and get an end stop. its a proper fitting that goes on the end of the pipe . uses compression fittings to seal the ends. you will have to know the size of pipe you want to sealo. may be you can take a small part with you.
oldun
747
162
St Neots
VW Campervan
Since 2001
Without a doubt as it is almost certain to leak and may cause a major fire/explosion.
If you have absolutely no experience with gas fitting then get some good advice from someone who has. There is a good reason why safety standards have been set for people who work on gas (and electrical) systems
Some people have no regard for their own lives or the lives of others and offer stupid solutions
Please bear in mind that advice offered on the internet must be initially viewed with great caution.
11,862
42,912
Planet Earth
A van
Over 25 year's
Go to caravan motorhome place and get one of their fitter's to blank them off and have it done correctly if you don't know how to do it:Angry:
do not boge whar lives are at risk.:thumb:
Geo
Trader - Funster
Jul 29, 2007
11,757
14,565
Mansfield,Notts
Autotrail Tracker FB
45 +years with breaks
Id have preferred it, if it wasn't mentioned in the first place:RollEyes:
Terry
11,932
9,073
Lincolnshire
Can't remember ;)
Hi follow the gas pipes back, chances are they will lead to a 3 or 4 way distribution valve that will have taps on it .Identify and turn off the appropriate one's.:Smile: Whatever you do DO NOT simply bend the pipe over
Terry
Jaws
23,836
72,444
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
He also seems to have failed completely to read the rules of the forum...
Is it just me that finds that comment extremely rude ?
Whilst it MAY or may NOT be accurate ( in this case condemning a practice used by gas fitters for donkeys years but now frowned upon deeply since the dent of H and S gestapo ) there are less obnoxious ways to say things
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Spose it depends on whether it is a generalisation or aimed specifically, could be either.
