Gas problem
Discussion in 'Motorhome Chat' started by LesandRuss, May 26, 2010.
  1. LesandRuss
    LesandRuss Read Only Funster
    Feb 7, 2009
    5
    Normandy, France
    Can anyone help!! Our gas works now and again!! We went away and the first stop couldn't get the gas through so drove to a dealer checked again outside the gate and it worked! had three nights away, switch it off ,then it wouldn't come back on!! drove fifty miles tried again and it worked! drove home tried it and it wouldn't come through again!:cry:
  2. C.L.S
    C.L.S Trader - Service & Repairs
    Jul 22, 2007
    410
    49
    A bit more information would be helpful , bulkhead or bottle regulator , type of gas your using etc....
    Mark
  3. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    as Mark (CLS) said...a bit more info needed but i would suspect the regulator being faulty.
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,283
    10,774
    E Yorks
    Another question - do you turn the gas off at the bottle when you travel?
  5. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    only turn it off when changing bottle .if you turn it off when travelling the gas fridge stops working. for about 11quid you can get a multi -purpose safety fitting comes with a gauge it cuts out the flow of gas in the unlikely event of a pipe breakage or excess gas flow. from bes the fittings people.part no.12763. google bes ...you may never buy fittings from anyone else again.
  6. Geoff
    Geoff Read Only Funster
    Nov 20, 2007
    39
    Evesham
    I think you miss typed the above part no.
    I believe the part no. should be 12673.
    Regards Geoff.
  7. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,855
    roche cornwall
    you are correct i wrote it down right and its in front of me now.they do a good cataloge if you tick the right boxes .
    there is also one in the reimo cat. but cant find a price .
    soory to confuse you
    cheers alan.
  8. LesandRuss
    Feb 7, 2009
    5
    Normandy, France
    Hi Mark bulkhead regulator, with button, press in for 5 seconds, propane gas,
  9. LesandRuss
    Feb 7, 2009
    5
    Normandy, France
    Always turn the gas off when traveling!
  10. alan'n'bev
    alan'n'bev Read Only Funster
    Apr 23, 2010
    20
    gas on or off
    do i leave the gas on or off while traveling on my fridge it as a safety cut off if the gas goes out or is it just better to use the 12 volt battery and just use the gas when we are parked for the night:RollEyes:
  11. pappajohn
    Aug 26, 2007
    29,704
    17,324
    YO11 2BD
    personally i cant see the point of burning gas, even with the safety valve, when you are already producing the leccy needed to run on 12v when driving.
    once the fridge is down to temp the 12v will hold it there until you turn on the gas or 230v hookup when pitched.
  12. alan'n'bev
    Apr 23, 2010
    20
    gas on or off
    yes your right i never thought of that, and i will take that advice, me been new to all this,great tip on here thanks to all:thumb::thumb::thumb:
