Gas Problem... Any suggestions ? (1 Viewer)
Denny
55
UK
Dethleffs
Since May 2008
We have just taken our Motorhome out for it's first run this year and found that although the gas oven is working fine, the gas hob is lacking in pressure on all 3 burners, it was fine last year !
We changed to a new cylinder ( propane ) but it made no difference.
Has anyone had a similar experience or can anyone offer any possible reason ?
The hob is 'CRAMER' Model 11:EK 2000 and the oven is Dethleffs the same as OUR Motorhome.
Denny. :Sad:
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
Probably a duff regulator. Do you have a spare one (maybe on a portable heater or a gas BBQ) you can swap it with to see if that solves the problem
Jan 11, 2010
2,747
9,569
Chester
Auto-trail
Well that`s our 13th year & still loving it.
Denny. :Sad:
As the oven is working fine have you checked the jets on the individual burners.
D
Denny
55
UK
Dethleffs
Since May 2008
Thanks for your quick reply Dazzer, but would'nt that effect the oven as well ?
The jets seem clear Rob n Chris.......I think the problem is before gas reaches them, but not sure !
dazzer
1,620
102
In my house
Virtual RV!!
10 Years
It would effect every gas appliance, is the water heater working ok and firing up fully??
If youve got a spare just swap it out and see if that fettles it. If not sounds like you might have a crushed/kinked pipe or a blockage in the pipework going to the burners.
D
Denny
55
UK
Dethleffs
Since May 2008
The boiler worked fine as usual and as far as I can see nothing could have happened to the pipes. I'll get another regulator and try that.
Thanks,
Denny
Scout
3,959
121,155
South Yorkshire
chic c line
12 years motorhoming, a lifetime of living
run a hover end around the fleam outlets, its suprizing what can collect there,
Oct 15, 2007
1,622
280
Five Roads Alyth
A class RV
since 2005
Our first RV was fine at the start but after a year although everything seemed OK it was the burners that showed up a failing regulator, kettle took ages to boil:Angry:, but cooker etc seemed fine.
