Gas-low butane or propane
Discussion in 'The Beginner' started by Annie21220, Oct 29, 2015.
  1. Annie21220
    Annie21220 Funster
    Oct 21, 2014
    45
    26
    Malvern
    Hi We are about to pick up our very first Motorhome in the next two weeks... And just wondered what people think about the gaslow system.... And also butane or propane which is preferable...
    Many thanks
  2. gloworm
    gloworm Funster
    Dec 30, 2008
    912
    1,730
    Cheshire
    Gaslow is a very good system and propane the most popular, good luck with your motorhome.
    Eric
  3. Robert Clark
    Robert Clark Funster Life Member
    Jul 12, 2014
    6,012
    11,479
    East Sussex
    Gaslow is great
    Just remember to turn the taps off, on top of the bottles
  4. HymerB544
    HymerB544 Funster
    Apr 25, 2012
    726
    729
    Near Truro, Cornwall
    When we bought the current van we had a twin 11kg Gaslow system fitted and we keep it topped up, though two cylinders would last for months to be honest. I think (but am not 100% sure) that the ga we fill up with at LPG garages is mostly propane (ie not pure propane). Anyway, although the system cost about £500 when we had it fitted, no more humping heavy cylinders and the cost to fill is so much cheaper. I think you can find lots of old posts and threads on this subject here, and there are other companies besides Gaslow who fit this sort of system. Gary
  5. Zigisla
    Zigisla Funster
    Oct 24, 2015
    1,107
    1,295
    Fareham, Hants
    I am having the same dilemma as well. My new unit will have a hose coming through the bulkhead connecting to a regulator which then connects to the bottles. I only have a 7Kg Butane, as my others were nicked from the folding camper, but the garage says he will swop it for a 6 kg Propane as the unit comes with the propane connector as standard. I am used to a bulkhead regulator on my folding camper, so the single hose looks weird to me. As the unit hasn’t been delivered yet, I still have the options to change to refillables or remain with the single propane. The Sunlight’s online manual does state 2 x 11Kg capacity.
    So which one?
  6. Popeye
    Popeye Funster
    Sep 5, 2011
    7,879
    17,773
    New Forest
    Hi @Annie21220, I picked my new van up back in May and it went straight to @eddievanbitz for several jobs but Gaslow was top of that list. My new van is far more Gas Hungry than the old one but I haven't had to lift a bottle since then.
    The gauge shows fairly accurately when one of the bottles is empty and filling it has varied between £6 and £8.30 but of course if it was the old exchange system, sometimes I would return a cylinder that still had some in it just to be sure I wouldn't run out whilst away; what a waste. I reckon that at £21-£24 a cylinder compared to NO Waste and around £7.00 for a fill without factoring in the hassle of carting bottles in and out I will get my money back in just two or three years.
    • Like Like x 2
  7. nomadic
    nomadic Funster
    Sep 27, 2007
    682
    182
    Shropshire based
    If you are thinking of having refillable tank/s fitted, give this guy a ring, Dave Newell 01954 587702, he supplies and fits Gaslow or Alugas, and he is very competitive.
    • Like Like x 2
  8. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    I have a fixed tank under the NH, but I have heard good reports of Gas-low systems. You need to to get the Gas-low cylinder(s) installed in your MH with a filling connector outside the MH, usually in the skirt. You then fill the cylinders at an LPG filling station, known in France as GPL, and sometimes called Autogas. This is usually propane but is allowed to vary a bit in warm climates.
  9. HymerB544
    HymerB544 Funster
    Apr 25, 2012
    726
    729
    Depends on your priority. We wanted less hassle filling up as we were going on a three month tour into France, Spain and Morocco and I just didn't want to be lifting heavy cylinders in and out (and it gets tougher the older you are of course). Then there is the fact that you cannot get straight replacements for the sort of refillable cylinders commonly used in the UK when you are abroad. I would always opt for Gaslow, or something similar.
    • Like Like x 1
  10. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,947
    17,612
    YO11 2BD
    If you get butane, which is doubtful, where are you going to fill them/it
    all fuel station LPG/autogas is propane...even abroad.
  11. Badknee
    Badknee Funster
    Aug 25, 2014
    3,739
    16,463
    notloB
    When we were tugging we used butane in summer and propane in winter as butane freezes @ I believe about +1 or 2 degrees C.
  12. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,569
    3,376
    Telford, Shropshire
    "When we were tugging we used butane in summer and propane in winter as butane freezes @ I believe about +1 or 2 degrees C."
    Sorry to be a pedantic bugger but Butane does not freeze at that temperature. That is the boiling point of butane. Ambient temperatures around or below that will mean the butane does not boil and turn to vapour. Propane's boiling point is around -47 C which is why it will work all year round.
    D.
    • Like Like x 2
  13. Badknee
    Badknee Funster
    Aug 25, 2014
    3,739
    16,463
    notloB
    Fair enough Dave, so in retrospect butane don't work when it get cold, stick with propane. (y)
  14. sedge
    sedge Funster
    Jul 7, 2009
    4,561
    4,068
    Nr Jct 3 M6
    It's usually the regulators that freeze, anyway, isn't it? But on a Moho, with the regulator being more 'enclosed' than in the A frame gas locker thingy on a caravan, I should think that would be a lot more rare, wouldn't it?
  15. Badknee
    Badknee Funster
    Aug 25, 2014
    3,739
    16,463
    notloB
    No the differend gasses work at different temps, propane works at much lower temps.
  16. MichaelT
    MichaelT Funster
    Nov 12, 2015
    115
    42
    Colchester
    Isn't LPG/Autogas at petrol stations a mix of propane and butane?
    The reason to use butane is it has a higher calorific value therefore you get more bang for your buck but below a certain temperature it will not 'gas' and stays liquid so is not suitable for really cold winter use.
    We are now looking to change from a caravan to a MH and are thinking about a gaslow system as we will not likely have a cooker with electric hob so our gas usage will go up plus I expect we will use more Aires in France etc. in future so have to power the fridge and hot water by gas.
  17. Easyliving
    Easyliving Funster
    Dec 4, 2012
    652
    1,581
    Norfolk
    We have had a Gaslow system fitted almost from the off. When we bought a new van 3 years ago part of the deal was the dealer had to move the system from the old van to the new.
    If you plan to travel in Europe (surely most motorhomers do?) for more than a few weeks then refillable cylinders really come into their own. Gaslow can supply all the adaptors so you can fill up anywhere. LPG from a garage costs a lot less than in a replacement cylinder from Calor etc.
    Paul
    • Like Like x 1
  18. Antonio
    Antonio Funster
    Aug 8, 2013
    77
    79
    Yorkshire
    Think you will find that the LPG mix depends where you are and that in southern Spain the butane% is higher than in the UK. Also that altitude affects the boiling point. I used propane in the house in Andalucia as I was 2,000 ft A.S.L. and it got very cold in winter. I have a gas low bottle and a propane one in the MH. I plan to get a Spanish propane bottle as well when I go back to Spain. Bit of a pain having to carry an extra bottle, but I have the room.
    • Like Like x 1
  19. SomeoneElse
    SomeoneElse Funster
    Apr 22, 2013
    576
    378
    Cotswolds
    This page attempts to give an indication of the propane/butane ratio of Autogas, but warns:
    This data should be seen only as to give you a perspective. Mixtures can vary from station to station and from company to company.
    http://www.mylpg.eu/useful/lpg-mixture
  20. vwalan
    vwalan Funster
    Sep 23, 2008
    7,601
    3,863
    roche cornwall
    i changed my cepsa bottle wednesday. 12kg only 14.35 euro . usually in spain swapping bottles is alot cheaper than using autogas /gpl.
    plus its only about 4 quid to swap maroc bottles in morocco.
    you do really have to be using alot of gas even in uk to get your outlay back. in uk use a 19kg bottle much better price than the small bottles .
