Gas leaking (1 Viewer)
Branston1080
54
33
3 years
Dear all
Any suggestions would be greatly appreciated. Returning back to the van tonight there was a distinct smell of gas. I opened up an air flow and then opened the gas locker to turn the gas bottle off. I could hear a faint leak on the screw in end ( sorry, I'm sure there is a technical term).
I had changed bottles the night before the connection seemed fine. I unscrewed and re screwed the connection, again could still hear a leak. I repeated 4/5 times but was not confident it wasn't leaking..
So I've changed bottles, I can't hear a leak. I'm still new to this and wondered if anyone had any thoughts or suggestions. Any tips on how to ensure I make a good connection?
I have got a carbon monoxide alarm - not sure if that helps in this case?
Thank you in advance:thumb:
scotjimland
2,324
10,060
A Woosh bang
Dear all
So I've changed bottles, I can't hear a leak. I'm still new to this and wondered if anyone had any thoughts or suggestions.[HI] Any tips on how to ensure I make a good connection?[/HI]
Yes.
check the face of connection for any marks or scores.. also check the female part on the bottle. any roughness will cause a leak.. If that's ok, tighten the nut by hand, then about another 1/4 turn with a spanner.. make up a solution of water and washing up liquid .. you only need a few drops.. turn on the gas, pour some it over the connection.. watch for soapy bubbles..
If you see bubbles, try tightening just a little more.. but don't over tighten... if it still leaks inspect again .. it's possible to polish out small marks on the the male connection.. but don't use anything too abrasive.. you may need a new pig tail..
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Carbon monoxide alarm would not work in this case, you would need a gas alarm,mounted low down as gas is heavier than air.
If its a propane bottle it could be that the connecting face is damaged, and this seems likely as your other bottle is OK. I would take it back to the supplier if nearby and tell them about it and insist they change it.
Geoffers
506
215
Groby Leicester
We have had 2 faulty 6kg lights recently. When the plastic bung unscrewed the gas was escaping despite the valves being closed.
If it leaks, get it changed.:thumb:
Branston1080
Branston1080
54
33
3 years
Top tip
I've tried the washing up liquid test, bubbles to start, another turn on the spanner, no bubbles.
Many thanks, feel happier that I'm not about to gas myself over night!!
You funsters are great:thanks:
aba
2,775
1,112
yorkshire
coachbuilt
dec 2009
i had this with the bottle mounted regulator that came with my van so started to carry a spray bottle in the gas locker with a washing up liquid solution in it to squirt on the connection when changing the bottle.
after a while i changed to a cleese bulkhead mounted regulator and gaslow easy-fit stainless pigtail which has a silicone/rubber seal since then no gas leaks and you dont need a spanner to change the bottle.
JohnM
650
179
Central Scotland
CClass
Since Feb 2009 and 40yrs c/vaning
Yes.
Very good advice couldent of said it better myself.:thumb:
scotjimland
2,324
10,060
A Woosh bang
you can buy leak detection fluid in aeresol cans under a fiver at any plumbers merchants
indeed... we used it at work..
.. but if you read the safety data sheet it is hazardous.. goggles and gloves should be worn when using ... water and Fairy is a lot safer.. and a lot cheaper... :roflmto:
