Gas it system (1 Viewer)
Mar 13, 2010
249
79
Can anyone help have two 6kg gas bottle s does any one know how many litres of gas they will hold .
also advice needed have two electric bikes also Honda scooter what would you take to Spain and Portugal scooter or bikes ?
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
I should have said 1kg = 2 litres and then it'd be shoes and socks off time :LOL:
Or it's half as heavy as water (y)
Oct 5, 2012
4,283
9,569
Ayrshire
Carado T132
5 years, feel free to ask me about the Carado!!
:) We don't half have some smarty pants on here... :)
if it's a gasit system then it's only designed to hold 80% of the badged weight so 4.8 kg x 2 = 9.6 kg in total = 19 litres approx :Eeek::Eeek::Eeek::Eeek::cheers:
Techno
Jul 28, 2010
15,475
20,756
May 2010
WRONG bottles hold their stated weight 80% is already accounted for.
Tanks yes you would be correct 50 litre tank holds 40
From Gaslow user instructions (same as Gasit)
IMPORTANT: FIRST FILLING ONLY. In some rare instances it is possible that on the FIRST FILL ONLY, the 80% shut- off may fail to activate. It is therefore IMPORTANT to pay attention when filling for the first time.
When using the 11kg cylinder - ensure your maximum fill is no more than 22.5litres. With a 6Kg cylinder - the maximum should be 12litres. If you are using a system employing 2 cylinders which are filled together, add the maximum volumes for the cylinders together. e.g. If you are using two 11Kg cylinders - your maximum fill should be no more than 45litres. If you are using an 11Kg and a 6Kg cylinder then your maximum would be no more than 34.5litres. Two 6Kg cylinders would be 24litres.
4,283
9,569
Ayrshire
Carado T132
OK I am not a smarty pants :)
Jul 13, 2008
3,736
3,792
Low profile
6 kg is 12 litres
You buy a 6KG bottle you get 12 litres of gas @£2 a litre :LOL:
Why does this say 11kg? Not that I've used it.
Techno
Jul 28, 2010
15,475
20,756
May 2010
That will be erring on the side of caution as it is not a legal legitimate means of refilling.
Bottles without automatic 80% shut off should not be refilled by joe public
Mar 16, 2016
1,072
6,601
Norfolk
Hymer S520
This would appear to be correct, as I've just installed a 4 Hole - 36ltr (18kg GAS IT Plus refillable bottle.
When I took my m/h to be filled (first fill), the autogas pump automatically stopped after 29ltrs, which would back up the theory of GasIt only holding 80% of the capacity stated on the bottle.
Pete
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes because their R67 bottles are effectively tanks unlike the old models and are rated in water capacity like a tank is. It explains that in the link you gave
"They are 36 ltr water capacity which means they hold 20% less than this amount due to automatic 80% float driven shut of filling valve in the tank, meaning you will never over fill the bottles even when only part of the gas has been used. They will always fill up to 80%"
Begs the question is the OP talking of regular Gasit bottles or R67?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Good link Jim (y)
So they say 11.5 litre to a 6KG while gaslow simply say stop at 12 litres if it don't stop itself :LOL:
