Gas it / Gas Low or alternative (1 Viewer)
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
I need to get a new system and wondered if anyone has already done their homework on the cheapest place to purchase either of the above??
Unfortunately, I'm limited to 2 x 6kg cylinders. I'll be fitting it myself so just need cheapest suppliers.
Terry (y)
Minxy
32,649
66,533
E Yorks
Carthago Compactline
Terry (y)
... are you sure you can't squeeze in an 11kg cylinder Terry? Don't tell me you made your locker tooooooo short! :D
Minxy
32,649
66,533
E Yorks
This site is pretty cheap and they have a price guarantee:
http://www.getgas.co.uk/
Oct 6, 2016
507
776
norfolk
C class
newbie
Terry (y)
Cant help with your actual question Terry but when we changed our system to gaslow we were advised to inform our insurers,,, apparently some companies view the change as a modification, ours didn't, but I still insisted they acknowledged in writing that I'd informed them.
Regards James, from dunear in Narfuk.
Minxy
32,649
66,533
E Yorks
Going direct to Gasit themselves isn't always the cheapest ... the one I've linked to is usually cheaper ... don't ask me why!!!
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Actually James @bigguspeckus, that is a very good piece of information.
Incidentally did they confirm in English or Narfook speak?
:hi5:
Al-Di
3,057
28,822
prestwich
Eura Mobil A Class
since 2013
we found gas-it the best on both our vans, What about an underslung tank????????????
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Anyone fitted the aluminium refillables to reduce weight? even though the cost might be quite a bit higher!
Minxy
32,649
66,533
E Yorks
Unless you are really tight on payload it doesn't make sense to me to buy lightweight bottles at quite a bit more dosh.
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Minxy
As a single MHer I tend to take more than most people as I don't have a partner or dogs or kids to keep me ocupied during the nights or inclement weather and as my payload is getting near the limit these are just one of the options I'm considering, but yes you are correct if I can get by with steel bottles then I will, I'm not one to spend money if I don't have to.
Best Wishes Tony
Minxy
32,649
66,533
E Yorks
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
Have a look at SafeFill. It's a different approach but works for me. Bottles are light and I can refill by taking them in the car. Also good for BBQ or gennie. Very flexible. Supposed to be able to see the liquid level but I've not found that so easy.
Terry
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Not me making locker tight but BESSECARR-Swift
Really tight on 11 kg :( The locker door is 295 wide and my 11kg gas it bottles on the Itineo measure 295 --short of removing one from Itineo and squeezing it in (it may or may not go in) I thought the 6s would go in easy :D--I have a 25 ltr under-slung tank that I may fit as this would give me the same amount of gas as the 2 x 6 kgs bottles or I may take the 2 x 11 kgs off the Itineo before selling :D if they squeeze into the locker :D2
Thanks for all replies so far (y)
Got to make minds up as to which van to keep now;)
terry
Brakers
1,182
965
Southampton
Chausson 768XLB
I'm Intermediate
Hi Rogher are you allowed to fill these when in EU countries?
Many Thanks Tony
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
I've filled-up once on a forecourt but the cylinder was in the locker. Luxembourg and silly low price. Wasn't stopped, so don't know if it's not 'allowed'.
musson
487
165
grantham
low profile
since Jan 2014
Fitted 11kg in bessacrr e584 from avon auto gas bristol 171 with pipe adaptor GAS It
Terry
Terry
11,932
9,075
Lincolnshire
Can't remember ;)
Well measured it all up and locker door is 285 with 11kg bottle 285 --can only fit 1 x 11kg bottle in locker as it 50 mm too narrow to get 2 in there --- thinking fitting the tank underneath may be best (y)
Emmit
8,032
17,749
Cornwall
Pilote Explorateur
Jan.2014
I feel for you Terry because it seems ridiculous in this day and age that the UK motor home manufacturers insistence on making van's with a letter box opening for gas MUST be losing them business in the market.
I know that when we bought our van', because a mate had had problems in getting a bottle into his Bessacarr I was jaundiced as to my choice of 'van.
Minxy
32,649
66,533
E Yorks
Many Thanks Tony
There will be places that'll refuse to let you fill them abroad and probably in the UK too ... garages etc are twitchy enough about people filling when they have 'proper' fixed fill points so I can envisage that it is likely that someone with just a portable cylinder will be refused even more.
Minxy
32,649
66,533
E Yorks
two
Aug 4, 2011
4,903
4,573
West Midlands
A-Class Fiat
They may be more relaxed regarding what you fill with lpg on the continent. I saw someone openly lift a container from the boot of their car, once. It looked like an 'ordinary' cylinder with an adapter on. No-one seemed to care much.
Minxy
32,649
66,533
E Yorks
Where was this?
There are some places that may allow that but there are probably a lot more that won't!
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
We're these normally returnable cylinders as in Calor type?
EX51SSS
6,073
28,561
North Manchester
Hymer Exsis A Class
since 2007
Where was this?
It may be possible there were a lot more that used to but now just an empty space.
Sep 12, 2016
2,266
5,038
Chesterfield England Tellus 3
Lunar Roadstar 800
6 years
We are looking at fitting two 11kg cylinders and an external point what winds me up is the price
Gasit = £380 fitted
Gaslow = £690 fitted
YES I know that Gaslow is supposed to be safer using steel hoses covered by PVC but we have been using the high pressure hoses on our Caravan for years and they get inspected every year as will the fitted system so unsure of the value of the hard system
so at this moment in time Gasit are winning
only 28 days before we collect Maxine al last
Minxy
32,649
66,533
E Yorks
There's something wrong with the Gaslow price unless whoever is fitting it is trying it on as there's not THAT much difference in the prices of the hoses etc!
If you're able to wield a spanner etc then there's no reason at all why you couldn't put the system in yourself and save the fitting cost altogether especially since access to your gas locker is easy and putting the filler either inside it or in the skirt would be quite a simple job.
