Evening all,
We bought our MH abroad last year (Rapido 666) and it has the fancy rupture type Truma gas tails in the locker, fitted with G12 ends (for German cylinders). In order to use up various Calor butane cylinders I have hanging around, I bought a G12 to 21.8LH (female) adapter (this one - http://www.socal.co.uk/toolbox/regu...r-for-use-with-calor-gas-4-5kg-cylinders.html), together with a cheap and cheerful 21.8 LH to clip on adapter to fit the Calor butane cylinders.
I thought I'd switched the regulator over to use the butane cylinder. However, in checking the van over prior to our trip to France next Friday, I notice that the cylinder supplied with the van (see through propane cylinder with G12 outlet), is nearly empty and nothing has been used from the Calor one I put in. I thought it was doing well!
That leaves me with a dilemma. I have three Calors (a 15 and two 7s), none of which is full. Fitting the best two would give me just under 13kg of gas, which might be tight at this time of year for a fortnight most of which is expected to be without EHU.
So I might have to buy a cylinder in France. I've read on a couple of older threads here that some French cylinders (Intermarche for instance) have a 21.8LH thread on the cylinder, which should fit the adapter I already have if I remove the clip on adapter.
Does this sound right?
I don't really want to buy anything else at the moment, as the longer term plan is Gasit/Gaslow/Alugas. I also read that the deposit on a French cylinder is nominal, unlike the Calor charge.
Even if it is correct, I might not chance it with the 13kg but will refill the 15kg Calor, giving me just over 20kg. It will be annoying giving half a cylinder of gas back to Calor but that's life.
Thanks in advance for reading this. I realise it's a bit long!
Tony
Tony
