Gas heater outlet (1990 fiat camelot) (1 Viewer)
Douzeper
Nov 23, 2010
234
58
Antrim, Northern Ireland
Newbie
I been testing gas appliances to see if they work ok, when the gas fire is on I expected fumes to come out of the flu, but there doesn't seem to be much coming out of it.
There are two holes/vents on the side of the van, one has hot air coming out of it when the fire is lit, should the hot air gasses etc not be coming out of the flu
The flu was covered in snow and it barely melted any, I cleaned it away but it is not hot or even really warm.
Is the flu blocked or does this sound correct?
wasp
1,724
18,180
Warsop
None gone caravannin
If your flue is boxed in it might be worth checking if it has deteriated and has holes in it. Either way I would get it checked cos what you have described sounds not right. Carbon monoxide you know silent and deadly.:Eeek::Eeek::Eeek:
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Nearly aint got one.
Caravan & motorhome 45 + yrs
Should be coming out the flue,,, check the tin foiley springy metaly flexi tube has not come away from the back of the heater or even come adrift where it connects to the inside of the chimney/cowl where it goes through the roof..
You wont smell it but it will kill you.. :Eeek: So dont use it till it is checked out...
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
With your description of hot air coming from the vents on the side,,, I would look to find out if the pipe has come away from the heater or as already said/suggested holes in the pipe..
There might be enough gasses escaping from the air vent to prevent the monoxide alarm from going off.. but still a lethal combination, if the gasses are going out the side vent you only need some wind to hit that side of the motorhome to stop the gas escaping from the vent and more getting inside.. :Blush:
And could the monoxide alarm be faulty... still all worth checking.. :thumb:
Douzeper
Douzeper
Nov 23, 2010
234
58
Newbie
I thought it must be wrong as it didn't make sense why the there was no heat/fumes coming out of the flu.
I'll get it checked before using it again.
Thanks for help.
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Great,,, worth it for peace of mind and safety..
Hope you get it sorted,, I dont think it will be much,,, but better safe than sorry,, let us know what the outcome is..:thumb:
Douzeper
Douzeper
Nov 23, 2010
234
58
Newbie
Will do!
What are the vents on the side for? are they to circulate air to the fire etc? why is there two?
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Will do!
I think if you could put a couple of photo`s up (2 Vents) we would be able to help a bit more.
Are the 2 vents you speak of letter box shape but bigger with sloping down slats,, and are they plastic. ?
Normaly if plastic they are just ventilation ducts for a fridge.. and not for taking heat due to being plastic.
Age of M.H and type/model would help. And it is possible some one has done a bodge job on the heater flue and decided to run it through the side, hence there being heat coming from these vents. Or are/is the vents small round metal type,, I ask this because on most American R.V.`s the exhaust from the furnace/boiler does come through a side entry tube type flue, but these because of the heat are always metal..
I stand to be corrected on all my suggestions, and perhaps a member who is more switched on than me can comment..
Look at this link to compere vets,, the second one down shows(Not Very well) the type of vent and set up for a fridge. Link Removed
old-mo
Extra Special
16,343
93,692
Weymouth. Dorset...
Woops!!!!!! Sorry,, just noticed the thread heading ( Gas heater outlet (1990 fiat camelot)
I think my first port of call would be to check the pipe has not dropped down where it attaches to the roof vent and where it fixes to the back of the heater and for perforations in the pipe..
Jaws
23,836
72,472
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Ummmm.. Just a thought...
The flue is not for the water heater, while the actual heater has a balanced flue onn the side of the van ?
That was the set up on my old Hobby
trevosky
183
27
Street, Somerset
c class
on and off 16 years plus
Provided the camper is the Autohomes Camelot the flue on the roof is for the water heater,one of those pilot light types,cant remember now but there may be a drain tap under van for the fresh water,long time since i had mine! cant understand why there is no zig unit above the switches though:Sad:
Trev
Douzeper
Douzeper
Nov 23, 2010
234
58
Newbie
Yeah Autohomes Camelot.
I'll go and take some photos.
So it may not be meant to come out of the flu. I haven't tried the water heater yet waiting on better weather in case anything is froze.
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
As already mentioned in a previous post, the flue on the roof is for the water heater. I think the heater had a balanced flue through the side wall if memory serves.
