Gas Goes Out When I Close Oven Door (1 Viewer)
Jun 22, 2012
3,759
40,779
Sherborne Dorset
Van Conversion
Since 2012
Advice please before I have to contact Nickwhale yet again about our new IH630RL. The oven is a thetford caprice MK3 with a separate oven and grill. The oven lights perfectly easily but if I open the door to check on food or add something the gas stays on but as soon as I close door the gas goes out. It will relight easily. The first few times I used oven it was very windy so I blamed that or my muppetry but now having been away a few times this is definitely the sequence of events. I cannot see anything in manual and the FAQs online are a bit sparce.
I think it must be a fault but then did wonder if it was a bizarre and rather irritating safety feature so that you dont lea ve the oven on by accident.
Thanks in advance.
43,319
49,401
Do you just have the oven on or the grill as well.
It may be you need the door open to use the grill and closing the door interupts the gas supply to the whole cooker.
Opps...just seen they are seperate.
C
Jun 22, 2012
3,759
40,779
Sherborne Dorset
Van Conversion
Since 2012
Thank you! I think it must be a fault, it's just that we have had so many problems that my heart sinks at the thought of yet another fight to get anything done. It all lights up initially so would have passed any initial checks so I can't blame anyone but the whole saga has been a real pain.
43,319
49,401
Agreed....it must be some kind of door safety interlock to interrupt the gas supply as just closing the door will never cause enough draft to put out the flame.
BUT....I had a look through the parts list for your model and there is no mention of safety interlocks or anything similar.
trekkin
332
490
Staffordshire
Rv
5 years but still learning
We had something very similar in ours,
Took a while to sort and I cannot remember the exact details, but to do with the roof vents and doors being open and wind direction, was odd that it would not stay alight on some trips (for days on end) but was fine on others not problems for days,
Maybe worth trying to make a diary with door /window and vent position to see a pattern. If nothing else will give you firm details time and dates when it went out, always a better argument that just saying that it always does
C
Jun 22, 2012
3,759
40,779
Sherborne Dorset
Van Conversion
Since 2012
Thank you so much for your trouble Pappajohn. I know it will be sorted in the end but all the problems have taken the shine off the excitement of a new van. I will contact them on Monday.
rrusty
258
212
Scotland
None sold sept 2019
Ours does the same and in the instruction book it says to light it and leave the door open a couple of inches for 2 minutes and then close it and it does indeed work.
9
9526
Carolyn,
Deb has just tried ours and it does not go out when you close the oven door, we are parked up in a well sheltered spot with no wind whatsoever though.
Daft question I suppose, but is your gas fully turned on? (the valve under the near side bunk)
If there is a truma service centre near you, I'm sure you can go direct to them without going through the dealer for a test/repair (this may be less frustrating)
Teasy2007
2,086
1,159
Rotherham South Yorkshire
Carthago Malibu PVC
W
We had the same problem and were told to leave the oven door open as well, just for a few minutes, it works ok, but you do have to keep an eye on it.
Ginny
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Carolyn,
Why would Truma repair a Thetford piece of equipment?
D.
Aug 5, 2012
125
99
Southampton
van conversion
since 1981 on and off
I have seen this before, not in a MH but in a fitted kitchen, if the cabinet holding the oven is air tight, when the door is opened or closed fast, the airflow can put the flame out. Try closing the door very slowly, if this works get some ventilation holes drilled into the cabinet
dave newell
3,262
4,369
Telford, Shropshire
Home converted PVC
26yrs
Well spotted, any advice on the cause/remedy for Carolyn?
Not especially, I find it difficult to give worthwhile advice on problems I have no experience of. I do find it hard to believe the manufacturers would fit a gas shutoff on the oven door as ovens by their very nature are intended to be used with the door shut. My guess (and at this point it is just that) is poor ventilation to the oven so that when the door is shut the burner simply run out of oxygen. Without seeing the actual vehicle I can offer no further advice.
D.
MikeandCarolyn
2,170
1,468
Worle,North Somerset
Since 2009
We had a problem with a gas ring-it lit ok but when you put a pan on it,it went out. Cleaning the jets cured the problem.
Btw-do you have a nice blue flame when it's lit? You should have.
C
Jun 22, 2012
3,759
40,779
Sherborne Dorset
Van Conversion
Since 2012
Thanks for the ideas, have tried oven when the sliding van door is open and oven stayed on so this oxygen idea maybe it. Think I will monitor it carefully for a week or two. I will try to be less heavy handed closing oven door as well.
C
Jun 22, 2012
3,759
40,779
Sherborne Dorset
Van Conversion
Since 2012
Andrew from Thetford came today and found fault instantly, it was the thermocouple, the screw was a bit loose, apparently it would have just got looser which is why it seemed intermittent and I thought that it was me doing something daft. Thanks for the advice though everyone. He explained exactly what was happening with it and although I listened intently I am afraid it went into my ear but then failed to connect with the technology receptors again so suffice it to say it was like not being earthed properly apparently.
