Gas fire (1 Viewer)
Mick James
47
12
Brechin
Swift royale 540
I'm a newbie
Hi all, my Carver 3000s fire is knacked and I was wondering if it was easy to take out and replace with another heater. I was looking at a Thermx on eBay a few weeks ago, what do you experts think?
vwalan
Sep 23, 2008
8,835
5,798
roche cornwall
lynton5th wheel
since a child
i have used thermex catalytic heaters for years . great bits of kit .
i also have used blue flame thermex heaters . not so keen on using them over night though .
my mate does he says its ok . they do have all the cut out bits on them .
M
Mick James
47
12
Brechin
Swift royale 540
I'm a newbie
thanks
Thanks for that VWAlan. Just need to know if the fire is easy to take out or is it a chew on, and is it easy to fit a Thermx in its place :)
3,872
5,270
The City of Henlow
Adria Supreme
Since 1980
My only concern would be with potential fumes. I like to be able to leave the heating on when it is cold. The Carver unit was designed for the task and fitted in such a way as to be safe with, presumably, good ventilation of any fumes. Would you feel confident about an alternative unit matching the safety aspects of the original Carver.
EBAY = Carver Caravelle 4 Gas Fire + Thermostatic Control Caravan Campervan Conversion
£29.95
0 bids
+ £15.00 postage
Alan
scotjimland
2,308
9,973
A Woosh bang
also had them in several caravans.. as Alan said.. good kit..
they do not produce CO gas, but do need adequate ventilation as they consume O2 and also produce a fair amount or condensation..
also bear in mind.. they are not approved for use in new build motorhomes or caravans..so that may affect you insurance.. worth checking..
personally I would have the Carver repaired or looked at.. there's not a lot to go wrong with them and IMO better and safer than a catalytic heater
11,842
14,071
Eastbourne East Sussex
Hymer low profile
Since 1972
Catalytic heaters don't produce CO if they're working properly and have adequate ventilation. They will produce carbon monoxide if ventilation is inadequate and are usually fitted with a safety device that turns them off if this happens.
I would much prefer a properly vented heater, as you have now. If it can't be repaired, replace it. Catalytic heaters can also be a bit smelly, and if anything flammable touches the inside (catalyst bit), it will set fire to it. Not safe to leave on if you're asleep or out.
M
Mick James
47
12
Brechin
Swift royale 540
I'm a newbie
£29.95
0 bids
+ £15.00 postage
Alan
Would the Caravelle 4 fit in place of the 3000s Alan?
FULL TIMER
795
717
NORWICH
SELF BUILT IVECO 75E17
BEEN BUILDING THEM FOR 32 years
remember if you do fit a replacement heater you must replace the silicon rubber flue O ring seal with a new one, they are not re useable.
oldun
747
162
St Neots
VW Campervan
Since 2001
£29.95
0 bids
+ £15.00 postage
Alan
My main concern would be the radiant heat from a gas fire. In a very small space radiant heat from the fire can easily overheat surfaces opposite the fire with the possibility of the surface catching fire.
