Gas Fire
Discussion in 'Motorhome Chat' started by maacracing, Mar 14, 2013.
  1. maacracing
    maacracing Read Only Funster
    Mar 11, 2013
    52
    10
    dundee
    Hello all, seen to be having a little trouble with gas fire (carver 3000) the pilot light ignites no problem but the main burner doesn't and will not come on.
    I have tried to do a little research it seems that Truma have bought out Carver and have discontinued Carver parts.
    Checked on ebay etc etc and it turns out that there are 3 different types of burner valves for the same
    gas fire.
    Just wondering if any one else has had a smiler problem
    Mike
  2. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
    could just be the thermo-couple, which sits in the pilot flame and when hot opens the main gas valve allowing the main burner to light.
    I believe the part number is 602699
    also, check the nut on the 'cold' end of the thermo-couple where it enters the gas valve....is it tight.
    if not, tighten finger tight plus 1/4 turn.
  3. maacracing
    Mar 11, 2013
    52
    10
    dundee
    Hi, Replaced the thermo coupling September last year as the fire kept going out.
  4. pappajohn
    Aug 26, 2007
    29,700
    17,316
    YO11 2BD
  5. maacracing
    Mar 11, 2013
    52
    10
    dundee
    Thank you very much for all of that will check it out this morning.
    Mike
  6. fleurette
    fleurette Funster Life Member
    Jul 30, 2012
    116
    59
    worcester
    Here's another site you might like to have a look at, http://www.arcsystems.biz/. They are very helpful and have some good links on problem solutions on there home page.
    Nigel:thumb:
  7. chatter
    chatter Read Only Funster
    Aug 3, 2009
    3,723
    939
    cheshire
    I concur with fleurette, Gary at arcsystems is the guy to contact, he is the guru of anything Carver , also on his site you can download the info for any carver system
