gas fire v television
Discussion in 'Motorhome Chat' started by marrod23, Oct 31, 2012.
  1. marrod23
    marrod23 Funster
    Sep 14, 2009
    552
    414
    uffculm mid devon
    Hi Folks can anyone explain to me when i turn my gas fire on i get interferance on my telly does anyone have the answer looking forward to your replies happy travels Rod:thumb:
  2. Phill D
    Phill D
    Dec 6, 2011
    4,414
    4,632
    South Wales
    I take it its in the van? Either way.... is the fan running on the gas fire? If so it is likely it is causing the interferance. Either worn badly bearings or a loss of a supressor somewhere.:thumb:
  3. aba
    aba Read Only Funster
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    depends on which fire it is.
    some of the trauma ones actually fire the ignition spark continuously when lit, this will cause said interference.
    • Like Like x 1
  4. marrod23
    marrod23 Funster
    Sep 14, 2009
    552
    414
    uffculm mid devon
    Hi Phil no the fan isn't running someone suggested that maybe it could be a weak signal
  5. marrod23
    marrod23 Funster
    Sep 14, 2009
    552
    414
    uffculm mid devon
    Hi Andy i think that might be the problem as it seems to happen when the red light on the knob stays on don't knoow if their is a solution cheers Rod
  6. scotjimland
    Jul 25, 2007
    28,936
    25,589
    are you sure about that?
    none that I've had worked like that ..
    • Like Like x 1
  7. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
    the one in my dads clicks constantly when it is lit on gas flattening the battery under the front panel.
    maybe its just his, otherwise i dont know but if one does it there is no reason that another one won't.
    perhaps continuously was the wrong word
  8. scotjimland
    Jul 25, 2007
    28,936
    25,589
    perhaps I misunderstood.. you're saying it's not normal .. and your dad's has a fault .. ?
    once lit the ignitor should stop sparking and only start if the gas runs out, or the flame detector thermocouple is faulty/not in the flame or the ignitor board has a fault..
    • Like Like x 1
  9. Diabalo
    Diabalo Funster
    Oct 14, 2007
    1,978
    384
    Rochester
    It's simple,
    Gas is one of the three classical states of matter (the others being liquid and solid). Near absolute zero, a substance exists as a solid. As heat is added to this substance it melts into a liquid at its melting point, boils into a gas at its boiling point, and if heated high enough would enter a plasma state in which the electrons are so energized that they leave their parent atoms from within the gas. A pure gas may be made up of individual atoms (e.g. a noble gas or atomic gas like neon), elemental molecules made from one type of atom (e.g. oxygen), or compound molecules made from a variety of atoms (e.g. carbon dioxide). A gas mixture would contain a variety of pure gases much like the air. What distinguishes a gas from liquids and solids is the vast separation of the individual gas particles. This separation usually makes a colorless gas invisible to the human observer. The interaction of gas particles in the presence of electric and gravitational fields can cause interference on some Tv’s.
  10. TheBig1
    TheBig1 Funster Life Member
    Nov 27, 2011
    7,350
    9,794
    Could be as simple as static electricity from the fire does the interfering stop if you touch the fire housing? If it does try ear thing the fire to the van chassis
  11. marrod23
    marrod23 Funster
    Sep 14, 2009
    552
    414
    uffculm mid devon
    WOW never thought of that:Doh:cheers Rod
  12. marrod23
    marrod23 Funster
    Sep 14, 2009
    552
    414
    uffculm mid devon
    Thanks will try it tomorrow cheers Rod
  13. pappajohn
    pappajohn Funster Life Member
    Aug 26, 2007
    29,698
    17,310
    YO11 2BD
    cant see it being a weak signal.
    digital signal is either there or not.
    you either get a decent picture or it pixelates and freezes.
    sounds like RF interference from somewhere to me
  14. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,201
    10,678
    E Yorks
    I suggest your Dad gets his fire sorted as it shouldn't do that and suggests that there is something wrong with the thermocoupler or possibly the gas supply is weak due to a blockage somewhere - it needs sorting. Gas needs to be given a lot of respect and any problems should be investigated and sorted.
    I assume you have a standard Truma type convector fire with a blown air function? I wonder if it is the blown air part of it is interfering as even when it's not being used I imagine it has an electrical flow to it? Just guessing though! :Blush:
  15. aba
    Oct 27, 2009
    2,792
    1,117
    yorkshire
  16. freelanderuk
    freelanderuk Read Only Funster
    Sep 24, 2009
    1,022
    541
    Saltfleet/Lincolnshire
    we have the same fire and once lit it the ignitor should stop sparking , there is something wrong with the fire
  17. SC 05 OUT
    SC 05 OUT Funster
    Apr 4, 2009
    3,289
    7,597
    doncaster
    I’m sure that passage refers to when you hold down the "gas on /heat regulator" control knob. When the gas is ignited and the thermo coupler is heated up and the knob released, the infighter should stop.
    I would have it serviced,
  18. jhorsf
    jhorsf Read Only Funster
    May 15, 2009
    9,157
    8,069
    DERBYSHIRE
    [ame="http://www.youtube.com/watch?v=4prqDn7QS8I&feature=related"]Fletch - "It's all ball bearings!!" - YouTube[/ame]
