Gas Feed Problem
Discussion in 'Motorhome Chat' started by StanandShirley, Jul 15, 2014.
  1. StanandShirley
    StanandShirley Funster
    Apr 29, 2014
    165
    210
    Chatteris Cambridgeshire
    Fitted a twin Gas-It System all working filled up tanks twice all good. Also fitted an external Barbecue point all fittings from Gas-It. Only recently tried the Barbecue and found it does not work no gas coming through. Fitted the tee piece from main pipe with a gate valve to the barbecue outlet and all pipes checked for stoppage all clear. After a chat with the Gas-It technical man, turned on all gas rings and oven then opened the valve to the barbecue point at this point gas flames went out on cooker. Lit gas again and pushed the purge button on the Truma Valve again gas went out on the cooker. As soon as I open the barbecue port all I get is a rush of gas for a second then nothing. I even bought another external barbecue fitting from Gas-It just in case that was a faulty one but no luck either. Gas-It are quite happy to refund me for the second fitting. Has anyone got any ideas what to do now?
  2. davejen
    davejen Funster
    Aug 21, 2008
    1,262
    718
    Kirkpatrick Fleming Dumfries
    Could be a faulty valve, try another.
    Cheers, Dave(y)
  3. StanandShirley
    Apr 29, 2014
    165
    210
    Dave
    Checked all valves and all clear and working or do you mean the Truma Regulator?
  4. dave newell lvs
    dave newell lvs Trader-Vehicle Services
    Oct 31, 2008
    2,613
    3,435
    Telford, Shropshire
    What appliance are you connecting to the BBQ point? It sounds lke the excess flow shutoff is operating in the reg.
    D.
  5. StanandShirley
    Apr 29, 2014
    165
    210
    The connection is a Bullfinch, insert and twist to open. Rubber pipe to barbecue with open close valve fitted. Taking of the pipe to see if I can smell any gas nothing after the first rush of gas.
  6. dave newell lvs
    Oct 31, 2008
    2,613
    3,435
    Telford, Shropshire
    The "Bullfinch" is the actual BBQ point, Disconnecting the pipe will simply allow unrestricted gas to flow which will exceed the flowrate the Truma reg will allow so the excess flow shutoff cuts in and stops the flow of gas, kinda why its called an "excess flow cutoff". Connect an appliance, a BBQ for example to the hose on your Bullfinch connector and see if it lights and runs OK.
    D.
  7. jb0371
    jb0371 Funster
    Jul 8, 2011
    462
    402
    Norfolk
    did that. Still doesnt work
  8. timdownieuk
    timdownieuk Funster
    Apr 9, 2013
    618
    329
    Ayr
    Have you tried connecting the barbecue, then resetting the regulator and then checking to see if gas is flowing to cooker etc.?
  9. StanandShirley
    Apr 29, 2014
    165
    210
    Yes tried that too, looks like I have a Gas Gremlin! Not to worry the Sun is shining just have to eat un burnt food. Thanks for all the help.
