Gas F[ow Refillable Cylinders
Discussion in 'Tech/Mech General' started by ramsthom, Jul 9, 2013.
  1. ramsthom
    ramsthom Funster
    Nov 23, 2011
    144
    89
    durham
    Iv'e had a quote for the installation of 2 x 6kg Gas Flow cylinders and all fittings for £450. Is this a reasonable price or can anyone suggest a place in the Northeast where I could have them fitted.:BigGrin:
  2. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    I paid a lot more so I think this sounds Ok. Ask for a certificate of installation to prove it's been fitted and tested by a competent person.
    Happy trails
  3. capinpugwash
    capinpugwash Funster
    Sep 14, 2008
    515
    630
    Hampshire
    Is there a reason why you are looking at Gaslow (I am assuming you mean them and not Gas Flow)?
    Other similar systems are available, and at better prices (Gas-it for example) and may be worth a look.
    As for fitters in your area, others may be able to help with that info.
  4. Minxy Girl
    Minxy Girl Funster Life Member
    Aug 22, 2007
    9,258
    10,758
    E Yorks
    This is the "Gas-it" kit (with locker mounted filler) for the same thing which would cost only £281.
    http://www.gasit.co.uk/index.php?_a=product&product_id=365
    So you can see how much you are being charged for the Gaslow bottles (which are virtually the same) and fitting, so no, I don't think £450 is a good price.:Eeek:
    They are VERY easy to fit, the hardest part being fitting the bracket to hold the in-locker filler which is just a matter of being able to drill the fixing holes for the bolts. If you went for the external filler it could be a bit more tricky depending on where you want to mount the filler but nothing particularly difficult. There is no reason why someone who is able to do DIY couldn't do this him/herself - it doesn't need a qualified gas fitter/motorhome technician to do it and so long as you leak check it (as you should when changing Calor bottles and/or putting on a replacement hose for example) there is nothing to worry about.
    One question to ask yourself is do you actually need two 6kg bottles or would one 11kg one do?
    A single 11kg set-up would cost £157 and give nearly the same capacity as two 6kg ones and also would be lighter as you only have one large bottle instead of two smaller ones and don't need the extra piping for a second bottle.
    http://www.gasit.co.uk/index.php?_a=product&product_id=379
    If you found that a single bottle wasn't sufficient you could easily add another at a later date if needed (assuming your locker was large enough).
    Shame you don't live closer as I'd help you do it, I moved mine from van to van with our last 2 vehicle without a problem.
    • Like Like x 3
  5. Candy Floss
    Candy Floss Funster
    Nov 16, 2011
    80
    67
    West Midlands
    Gaslow
    WE have one 11kg from Autogas200, they are resaonable and light weight as they are Aluminium, Bill fitted himself no porblems. Also at Stratford recently we bought 6kg gaslow and contacted Autogas200 who very very helpful with parts needed and both are connected up. Rose(Mad Floss)
  6. PhilandMena
    PhilandMena Funster
    Feb 9, 2008
    2,772
    3,759
    Corby, Northants
    I find a major benefit of having two 6 KG bottles is that when one runs out I know I still have gas from the other bottle to use so never totally run out of gas. I have the manual changeover valve installed too so I can do this.
  7. brynric
    brynric Funster
    Sep 5, 2009
    328
    310
    Worcestershire
    I find having 2 bottles an advantage. I have an 11 and a 6, I generally run off the larger one and then know I have to top up when I move to the smaller. But I also know there's no rush.
  8. 54mud
    54mud Read Only Funster
    Sep 18, 2009
    100
    53
    Stone, Staffordshire
    There is also safefill.co.uk plastic bottles that are refillable and do dot need any fitting.
  9. Tibs
    Tibs Read Only Funster
    May 22, 2012
    72
    39
    Essex
    We have also looked at safefill but still haven't decided. Has anyone got any experience or advice regarding these? And also does anyone know of any problems regarding refilling?
  10. ramsthom
    ramsthom Funster
    Nov 23, 2011
    144
    89
    durham
    I would like to thank everyone for their advice regarding the refillable cylinders. I received a very competitive quote from Autogas 2000 for 2 x 6kg cylinders with external fill point for just under £400. Its near Thirsk, North Yorkshire and is only 40 miles away. Thanks again
  11. Steve
    Steve Funster Life Member
    May 8, 2013
    1,564
    1,841
    Compton Berkshire
    I run with 0ne 6kg (calor) and one 8kg plastic refillable. The reason being the 8kg is cheap to refill but not so many garages have LPG and the 6kg is available everywhere and you need a bottle to swap or it’s expensive. If I know I will be in one place a long time I also have an 18kg. Refilling can be tricky as most garages don’t want you to fill bottles but It can be done discreetly. If your were to have a fire and you tried to claim i would not be surprised if the insurance company would want to see some insulation paper work. But I am sure others on here can high light the regs on lpg for MH and caravans.
    Steve.
  12. mojo
    mojo Funster
    May 1, 2009
    132
    48
    Essex
    ext refill
    Best to have external refill because certain places in Europe they frown filling up bottles directly but no probs if it looks like a normal fill up on the forecourt.We had one garage attendant in France rush out to stop me but I pointed out that I had only opened the gas locker to make sure the bottle was in closed position before filling through the ext filler.He was ok with this.
    Just changed vans and the dealer moved over our gas bottles and said he had never heard of this issue and always fitted the fillers inside the gas locker.
  13. Brightspark
    Brightspark Funster
    Dec 27, 2010
    240
    107
    Northallerton , North Yorkshire
    Don't forget to mention to Autogas that you are a motorhomefun member & they will give you a decent discount & free delivery. I got a quote for 2x11KG aluminium bottles + all the fittings for £460 delivered.
  14. Armytwowheels
    Armytwowheels Funster Life Member
    Aug 10, 2012
    4,065
    6,594
    Spain for the winter
    Another great thread today. I have learn't a good bit of motorhoming stuff this morning, thanks everyone.
    We were thinking of one 11kg refillable and one 6kg Calorlite (as we already have one of these). The thinking behind this is the 11kg refillable for the van and the Calorlite for the BBq and emergency's should the LPG run out.
    I have to say the gas-it example makes this combination even more tempting- thanks Minx:thumb:
