sdc77
Nice post @Minxy Girl .. safety is obviously important
I still think transporting is fine and not exempt on insurance.
Maybe, maybe not ... it would certainly be worth a phone call and/or check your policy details to see if it has to be in a 'proper' locker beforehand though.Nice post @Minxy Girl .. safety is obviously important
As Jim said, heater vents in the garage connect to hab area & no drop vents in the garage.But it is safe. Why do you think it's not safe?
And of course the bottle would be closed, unlike whilst in use with multiple gas connections in the gas locker, and the multiple gas connections inside the body of the motorhome, and the numerous gas appliances, also not in a gas lockerAs Jim said, heater vents in the garage connect to hab area & no drop vents in the garage.
Maybe we should start a thread on how dangerous it is to carry a motorcycle with all that petrol in the garage as well.
.. unfortunately a closed bottle can leak ...And of course the bottle would be closed, unlike whilst in use with multiple gas connections in the gas locker, and the multiple gas connections inside the body of the motorhome, and the numerous gas appliances, also not in a gas locker
The difference is that you don't SLEEP in your car, it's not just about explosions, you could be gassed too ... if you have an alarm to detect LPG it might wake you up but that's obviously more likely to be near the cooker rather than near you in the bed over the garage. If you want to risk it, thats up to you, but for the sake of a bit of 'fettling' to make a locker for it with base vents is it REALLY worth it?@Lenny HB That's just an opinion. It's quite safe (my opinion) . We transport gas cannisters for the van and barbecue in the car regularly too. No issues there either.
Yes but the rest of the MH has gas drop vents and not loads of clutter blocking them. In a garage there usually aren't any drop vents but even if there are the chances of them being clear for the gas to drop out is very unlikely.But there are more gas connections inside the motorhome than in the "specially constructed" gas locker
I'd be more worried about the lack of crash testing and crumple zones in a crash than an additional gas bottle
I never said it was safe, I just said I did it.Just because you do it, does not mean it is safe and you shouldn't be giving the ideas to others.
No ... unless of course you sleep in the car!So if you go to fetch a gas cyl in the car does it need to have a hole drilled in the boot floor and a secure attachment!!"!!!!!!. We just got a gasit cyl so easy and cheap to fill the main advantage is you can top it up. Before that had a small propane as back up
Not always bikes, sometimes between the spare wheel and three crates of beer.No but it should be upright and secured. Not just wedged between something, as someone said they do between bikes in garage of motorhome.
N
and a generator full of petrolNot always bikes, sometimes between the spare wheel and three crates of beer.
but keeps H & S industry employed.
Please don't underestimate the effect of leaking gas ... we were in a fire in a MH due to leaking gas it it was NOT fun I can tell you! We had a 5ft 'blowtorch'!The only thing that has been mentioned that really matters is: carry it upright. If it's on its side and the valve leaks it will leak liquid that turns into lots of gas. Upright & it will only leak gas. If it leaks at all that is. I invariably have a chuckle at safety obsession. The classic to me is the MH driver. He/she is in a vehicle that will, given the right circumstances, propel its fridge and lavatory through the windscreen whilst peppering survivors with the contents of the lockers. And that's after they've survived the scooter trips undertaken before leaving site.
Reminds me of school science lessons - lighting the gas tap was so much more fun than lighting the Bunsen burnerWe had a 5ft 'blowtorch'!
I don't for minute - and I like your idea with the box. I don't think the box is essential though as long as the cylinder is held upright. A couple of gas drops in opposite corners of the garage should do the trick.Please don't underestimate the effect of leaking gas ... we were in a fire in a MH due to leaking gas it it was NOT fun I can tell you! We had a 5ft 'blowtorch'!
The problem with just standing the gas cylinder in the garage 'as is', is that any escaping gas can seep round the whole of the garage floor and as there will be other bits and bobs on stored in it, these will restrict/delay/prevent gas reaching and then escaping through any drop vents that have been installed, however if the gas is in a box any leaking gas will be contained within the box itself then go straight out of the drop vents without spreading round the garage so a LOT safer.I don't for minute - and I like your idea with the box. I don't think the box is essential though as long as the cylinder is held upright. A couple of gas drops in opposite corners of the garage should do the trick.
As you say though carrying a bottle in a car for a short time is different to it being in a MH all the time where you sleep, eat, use naked flames etc ...The issue is a bit like carrying cylinders in a car. The advice is simply to carry them upright (and the car is certainly pretty well sealed with no gas drops). The advice presumes the cylinder doesn't reside permanently in the vehicle. Different perhaps to the relative permanence of the MH garage arrangement where it is probably worthwhile at least arranging gas drop ventilation.
Would this be an appropriate time to say I've put a 907 on sale in the Classified?
I thought not!!!
Off topic but.
Are under slung gas tanks a whole lot safer ??
