Gas burning orange (1 Viewer)
Mikey RV
4,847
23,853
Devon
Burstner Elegance I821G
Since 1977
Trying to cook tea tonight, well the wife is and the flame is more orange than blue, normally it is all blue. We are on propane. Any suggestions please. Wife is in panic mode and I am hungry.
Fletton
1,531
2,501
Lincolnshire, UK
Knaus Sky I Plus 650LG
First MoHo - April 2015
Oven or Hob?
Hob... Did you spill something on it previously and missed it? I know the tops are screwed down on MoHo burners... Whereas on "normal! hobs you can remove the "cast iron" top and clean the aluminium "gas spreader" bit if it gets clogged..
Apr 25, 2012
794
826
Near Truro, Cornwall
It could be just dirt or dust in the burners, or it could be that some thing you are cooking has got onto the burner and that is causing the flame to burn orange. Or it could be that your burner is not getting enough oxygen through and conversely, is producing carbon monoxide. I believe it is possible to get at the adjusters under the burners if you know what you are doing, but you would need to let it cool down first and (if you have one) consult the cooker manual. Unfortunately mine is in the van, in storage, or I would take a picture of of th relevant section and post it. Hopefully someone else has better advice. Gary
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
All three gas rings and the oven are burning orange.
Jaws
23,821
71,961
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
Not good ... Unless someone has been going made with a load of calcium chloride !!
Seriously.. An orange flame indicates a lack of oxygen so the gas is not fully burning..
As mentioned, a very serious threat of carbon monoxide build up
Oddly enough sea salt can cause the same looking problem
Don Quixote
2,966
5,257
Lost in La Mancha, Spain
VW T6 Campervan
Have you used a spray like an underarm or fly spray or fresh air spray or a smelly candle? within your MH as this can cause the flame to burn orange rather than blue as we discovered last year. open a widow or the door for 5/10 minutes and then relight gas should be back to blue flame. If this fails you have a problem that needs fixing as already stated above is dangerous.
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
Windows and doors open. Please keep suggestions coming. We are trying to find a motorhome dealer in the area. We are just north of Bayonne on a aire.
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
Thanks for replys folks. We are going to try and find a repair service near us tomorrow. Internet not too good so will go to information centre tomorrow
Sep 25, 2009
789
1,381
south yorkshire
coachbuilt
since 2004. Tugger 10 years on and off
Sounds like regulator.I had similar problem.After a while I turned off gas rings and flames carried on coming out.I had to turn gas off at bottle.My regular had failed.Luckily I carry a spare bottle regulator.so I bypassed the fixed regulator untill I got home.Funnily since fitting new regulator my oven work's better.It never seemed to get hot enough.
PeteH
6,853
9,029
East Riding of Yorkshire
Rapido, 999M.
18+yrs plus 25+Towing
I would concur with the foregoing, especially viz getting it checked. Also when did you last fill and where?.. Odd places have been known to dispense low calorific value gas`s?
Pete
Nov 6, 2013
1,403
3,106
S. Ayrshire
The usual
Since the beginning
Where are you ? Someone on here might be able to suggest someone local
PeteH
6,853
9,029
Rapido, 999M.
In the Early 2000`s we used to lay over for a break at at site nr St Jean du Luz. The site owners where very helpful and informative when I had issues with my Brakes?. There was also quite a bit of industry to the North of Biaritz.? on a couple of industrial parks? which is where I got parts once. for a Fiat.
Pete
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
Update...just tried the gas this morning and all is back to normal now. No I had not been drinking last night, but just wondered if it was a bit of crap in the system and has now cleared of that's possible. Thanks once again for all the response. (y)
DuxDeluxe
14,627
72,220
Planet Zog
A woosh bang van
since 2008
Pleased to see that it is sorted, however it should still be checked by a professional ASAP in case it happens again and you don't notice. (y)
Don Quixote
2,966
5,257
VW T6 Campervan
As I posted it could have been something you used or something taking the oxygen from the air, but please keep an eye on it for a while just in case.
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
Not all good just been out for a walk came back for cuppa and has is orange again so off it goes until we get it checked.
Wickolad
490
542
Wickersley
Newbie to MH, 20yrs+ Caravanning.
Just an afterthought but have you tried the gas fire? You can see the burner flame through the inspection window? If this too is burning orange then it may well point to regulator as mentioned above as it then suggests it not just the cooker at fault.
Either way, orange flame indicates unburnt gas and therefore Carbon monoxide. Therefore it could also mean you need to keep hot water boiler off as well until resolved.
Carbon monoxide alarm is a must have in a caravan or Motorhome & any living accommodation in my opinion.
Hope it's sorted soon.
Mikey RV
Mikey RV
4,847
23,853
Devon
Since 1977
I reckon we already know.
New regulator required.
No prizes for the right answer but will let you know the outcome. But think you will be right. Still it's got to be done we are away for another 4 months yet.
