How many gas bottles .can you take in moterhome on ferrys and what type of gas is best for france and spain.
my lpg tank is 200 litres,, do i have to go with less then??Most ferries it is 47kg of gas max of 3 cylinders that must be adequately secured.
Every country has it's own gas bottles and they are not interchangeable, re-fillable cylinders are the best option if traveling through various countries, depends how much gas you use.
That's about a 100kg so the answer is yes, max is 47kg.my lpg tank is 200 litres,, do i have to go with less then??
Two 6 kgs last us about 8 weeks in Spain in the winter. Think most is used on heating. BUSBY.Thanks lenny. Will be going for about 7 to 8 weeks . Will be useing electric sparingly if metered . Will be anewbie touring with moterhome. by the way we have looked at your photos of france2014 . Great .
I've not seen ferries give a limit especially where it is used for propulsion too. Only that it must be turned off.my lpg tank is 200 litres,, do i have to go with less then??
Brilliant..thanksYou can get free bottles from Supermarket Chains (we use Super U) in France, you need only pay for the gas. You will then need to buy a French regulator from a Brick o Mat or some such. It is then simply a matter of finding the nearest Super U (there are hundreds) when you need a refill.
We have a tee piece with a Calor regulator and a French one piped together, we simply swap between them.
