Gas bottles on the euro tunnel (1 Viewer)
joncris
1,101
1,603
Where it matters
Rimor Katamarano 12p +
Good then you've now't to worry about.
Me I have them fitted to my present and previous MH as it saves guessing when the gas will run out AND should they suddenly decide to follow the rules I wouldn't want a holiday ruined for he sake of a few quid
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
They won't prove you only have 80% and they're not concerned about how little you have left.
If in doubt carry your gas bottle certificate of compliance.
Allanm
5,431
9,192
Cotes d'armor, France
Burstner Harmony TI 736 G
Since 1987
We have a gauge on the tank and a display on the dash. We always get asked if the gas is off but rarely check when I say the "gas taps are inside, you don't mind dogs do you? There are 2 in the van"
Coming back on Monday, the guy at the French side asked if the taps were off ( I actually turned the one off on the tank underneath) and he looked at it then asked if it was more than 75% full. It wasn't, but he didn't check. No-one has ever checked the gauge on the tank, but its plain to see if you lie under the van and get your head up between the gas tank and body skirt....
Allan
Techno
Jul 28, 2010
15,475
20,756
May 2010
When you buy a tank sender unit (gauge) it states that it is not calibrated nor accurate, only a guide.
The only way to prove the contents is to know the weight of the tank and the weight of LPG (1L of LPG weighs 0.51KG). They are not going to start taking vehicles to pieces to prove the 80% shut off is working correctly :LOL:
joncris
1,101
1,603
Where it matters
I'm only repeating what their rules state quite clearly in black and white. What they might or might not do is a whole new matter BUT and I expect its a big but if anything goes wrong because no one checked I guarantee there'll be hell to pay. Remember the Roll on Roll off ferry traveling to Zeebrugge (better known even before the incident as Roll on and Roll over ferry's).
Don't just rely on the providers getting it right because as costs are always a factor there will be a cutting of corners (as in the ferry disaster) and a lack of inspection hence safety doesn't bode well at all
Sep 23, 2013
2,583
8,729
Lincs
Globecar Campscout
Tanks & bottles are designed to be 'full' when 80% of their internal volume is taken up by liquefied gas. So pretty much every contents gauge designed to be read by the user shows Full at the 80% mark - it doesn't show 80%.
Add to this that most contents gauges by design don't move off the Full mark until the tank is below 50% & it becomes apparent that reading the contents gauge is no help at all in establishing whether or not the tank contents fall within the regulations.
I'm sure tunnel management are well aware of this.
Techno
Jul 28, 2010
15,475
20,756
May 2010
Correct so it doesn't say "even more full" if it has 90%
What they really mean is that refillable tanks/bottles must be designed to only carry 80%. There is no way to ascertain that in a spot check, a degree of faith is applied.
Minxy
32,621
66,432
E Yorks
Carthago Compactline
Sorry but you do NOT need a reader ... in all the years we've been going abroad, both on ferry and Eurotunnel, we have never ever been questions as to the quantity of gas in the bottles, only whether they are on or off.
Sorry but I think your wrong
From the Chunnels own website. The highlight in red is mine
Fixed gas containers (tanks, etc.)
For the purposes of this text, this means fixed containers that are permanently installed or fixed in a vehicle and are refillable from outside the vehicle.
The quantity of gas is limited to 47kg (or approximately 93 litres) maximum for a single container and to 50kg (or approximately 99 litres) maximum in the case of several containers. Each container must be no more than 80% full.
The quantity will be checked via the gauge or remote indicator but if neither are present, the vehicle will be refused.
I said you do NOT NEED a reader ... I did NOT say that they hadn't request it be fitted in their blurb ... the real situation is different as I and others can attest to ...
Minxy
32,621
66,432
E Yorks
I'm not worried, I fitted it.
Up to you of course ... but I stand totally by my suggestion - you have only ONE bracket on your pipe so the pipes themselves are taking some of the stress due to movement, more than they would if they had more brackets on ... until our pipe decided to come apart from the coupling there were no signs it would do so ... your risk.
Techno
Jul 28, 2010
15,475
20,756
May 2010
There is no movement.You are judging from a picture, I think I am better placed to judge.
How many clips have you on your pipes now? not one leaving the manifold has a clip. I reckon you need about 10 and I'm coming to check! make sure you don't park near me until we have photos :xrofl:
Minxy
32,621
66,432
E Yorks
Wrong I'm afraid, that was the situation after the fire but before it was all stripped out and redone under the supervision of a CORGI registered LPG inspector (this was back in 2005) and the replacement piping was a thing of 'beauty' afterwards, unfortunately I haven't got any photos of it and we haven't got that MH now.
As for their being no movement in your pipe ... regardless of whether you can feel any movement yourself, during transit it WILL have some vibration going through it and it is this that can weaken joints etc ... having been in such a frightening situation myself I certainly would NOT risk it for the sake of a few brackets ... you also need to satisfy yourself that, if something did happen, that your insurance company would pay out ...
If you are happy with your arrangement then, as I said, that's up to you ...
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes completely. I would have a look at your fridge and hob connections you'll crap yourself
joncris
1,101
1,603
Where it matters
The reader and the turn off and on valve combined that was fitted in our previous MH was attached to the gas bottle neck and the pipe screwed into that so little or no chance of that dislocating. In our present MH the bottles are refillable and therefore a permanent fixture AND they have a reader which I believe is a standard fit
Minxy
32,621
66,432
E Yorks
Minxy
32,621
66,432
E Yorks
????? We have a Gaslow bottle with a 'reader' (ie gauge) on it but it can only be read with a mirror due to the way the bottle fits in the locker ... our filler is also within the locker ... but we have NEVER EVER EVER been asked how much gas there is in it or when we had standard Calor bottles either.
Minxy
32,621
66,432
E Yorks
a typical fridge connection, clips in abundance.
... the difference being that the converter did that as part of the original installation and therefore the insurance company would accept that it wasn't due to YOUR 'negligence' if you made a claim. With a self-installation IMV it would have to be clearly the best it could be if they were going to honour a claim - I'm not saying that you are negligent, but just that I can't see the point in risking it for the sake of a couple of clips!
Techno
Jul 28, 2010
15,475
20,756
May 2010
You used a professional who made a bollox of it and a gas tester who did the same. You don't do anything yourself.
I do my own work because I am competent and I don't have things go wrong.
As for perceived risk, that is your perception.
This was done by the "pro" and he even put the stepped olive the wrong way around in the 8to10 reducer
Techno
Jul 28, 2010
15,475
20,756
May 2010
Using a brass T on a steel gas pipe is more likely the reason your fitting came apart rather than the lack of a clip. All the nuts and olives on your manifold and pipes are steel on steel.
fire-2-jpg.49497
955matt
955matt
208
130
bexhill on sea
Since 2012
Thanks again , I won't worry about how much is in the bottles, I don't have a gauge and they are removable anyway.
Off too the big D park near Paris for my son for Christmas and Boxing Day as a surprise , then off skiing for the new year ( snow permitting ;-))) )
Cheers Matt
