Gas bottle size Alugas (1 Viewer)
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Phoned Alugas yesterday and think I will be going ahead and buying one off the 11k bottles, my lockers is big enough for two but only have 2 x 6k bottles in just now.
The difference in price between a steel and alloy one is £60 and the difference in weight is only 4k so the fact I will only have one of these does the 4k really make a difference I have also just had the van replated to add another 350k so should be ok weight wise.
So has anyone else got the steel one or do you all have the alloy.
canopus
6,129
10,241
rural Lincolnshire
Carado CV640 Pro
Since 2010
Get 2 refillables Gerry, so much cheaper when you fill up. You can always keep a spare calor bottle at home or in the van garage :thumb:
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Thought about two Ken don't know if I could justify the price as we only use about two six k bottles a year so will take a while to get the cost back for one never mind two. If we go for the one we can always add a second if we start using it more.
Jan 27, 2009
872
3,358
Leyland Lancs
since 2001
As I stated last week:- 11Kg Gaslow cylinder with gauge, £120 including delivery from Hamiltons. Is this the price comparison you're using?
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Have phoned them assuming its the correct company in Bangor NI for the bottle and refill kit they are coming out at £242 and would need to purchase an adapter if wanting to keep a propane bottle, Alugas are £240 including adapter and still to take 5% off that price for fun discount.
canopus
6,129
10,241
rural Lincolnshire
Carado CV640 Pro
Since 2010
Yes Gerry but you will have to drive down to Thirsk to see Alugas :ROFLMAO:
Have you considered a single underslung tank from Alugas. We did but didnt have enough room/place to fit one - prop shaft was in the way? You would free up your gas locker completely then:thumb:
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Yes Ken had thought of the fitted tank again though hard to justify the cost as it would be a bit extra.
As for going to Alugas its free delivery so no need and should be able to fit it myself with a hammer and screwdriver :ROFLMAO::ROFLMAO:
Dec 6, 2011
11,554
25,336
South Wales
Coach built Adria
hi Gerry, we have a steel 11kg gasit like you could not justify ( at the moment ) the cost of 2. can always be retrofitted anyway..
its an easy fit youll have it done in an hour.:thumb:
Jaws
23,830
72,328
Thetford Norfolk
C class, Chieftain
since 2006 ( I think ! )
I fitted one x steel 11kg refillable bottle and went for the option of having the pigtail switchable to a standard Calor bottle ( nice chap at Autogas explained it all and I seem to remember the price difference was just a couple of beer tokens )
When doing long out of the way runs I carry a spare 6kg calor bottle 'just in case' but in all honesty have never yet had to use it !
Jan 27, 2009
872
3,358
Leyland Lancs
since 2001
Sorry Gerry, thought you was after a replacement bottle only.
haganap
12,754
26,414
planet earth
Niesman+Bischoff 79e
I'm an oldbie MH number 10
I have only ever had one refillable gas low bottle. 11kg. I then have an emergency calor light in the locker.
In 8 years we have never been caught out,
When going away in winter for more than 3 nights, we use the small bottle first, I know even in -20 with the heating on 24/7 we can get 3 days out of a full gas low ...
When skiing we take 1 gas low and two further 11kg bottles this gives us 9 days without problems high up in the alps.
I personally based on my 8 years of using refillable bottles would not see any need for shelling out on two bottles for the amount you use.
The only difference I will/might make is to install an underslung tank to increase space as I want to use my gas locker to store my genny
autogas 2000
7
16
Thirsk, North Yorkshire
LMC
Hi Gerry,
I am out of the office at present down at Newark show so have limited access to my usual Internet connection so I am typing this out on the iPad.
If your down or coming to Newark show do call in as we are on stand w17.
With regards to alugas bottles then another option is the rv cylinder that we stock as these are steel and available in 11kg, slightly heavier but same make as Gaslow. We have both on the stand just in case you want to compare.
There are some details on our autogas leisure website under the bottles section at the bottom there is PDF for both Alugas and the Rv cylinder.
Just a thought so that you have both options.
Just a note for others show at Newark looks good and ground conditions also good at present. no snow and it's not raining so all positive .
Regards
Chris
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Hi Gerry,
Regards
Chris
Thanks for the reply Chris I won't be making the Newark show so won't be able to pop round for a chat. I think I have made my mind up :ROFLMAO::ROFLMAO: you seem to be offering the best deal for me just weighing up my options regarding steel or lightweight bottle. I'm hoping to have it before Chester rally as my propane bottles are empty so this is the best time to change, will let you or your company know by Friday.
Thanks again for the help
Gerry
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Phoned Autogas today and got a very helpful lady called Wendy she talked me through everything I needed and advised me on a few other things I might need in the future. As it was after 1 when I phoned she wasn't sure if they could get it out today got a call back 20 minutes later to say all packed up and on the van so should be here tomorrow.
Hopefully have it fitted for Saturday and filled up for use at Chester not that we will need heating as I'm sure it will be roasting anyway:ROFLMAO:
Will let you all know how it goes.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Autotrail TrackerEKS
Since 2010
Newly fitted 11 kg Gasit bottle, then "off"
Filled up the newly fitted Gasit 11 kg steel bottle yesterday,( 21.8 ltrs of gas ) checked for leaks with the supplied spray, No leaks... Ready to rock and roll now, Ferry booked 3 April to Calais, then down to Dordoigne area and " Pootle " about there in river valleys, look at Limousin, "pootle" there and then play it off the cuff and see what the weather dictates. Might have to head for Spain if the sun is'n't up by then.. 3 months to find some..
. .Mitch and Jenny.. :thumb:
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Hi Mitch and Jenny just wondering how much did it cost to fill the bottle.
Sep 16, 2010
3,010
2,858
Bungay Suffolk
Since 2010
Hi Jerry.. £13.08 plus the dreaded. Just need the Aires book to find all the Gas sites in France, it lists them in the back... Good luck Mitch..:thumb:
Jul 1, 2010
3,198
33,266
SW Northumberland
Hymer B 588 DL
Since September 2010
Hi Gerry, I topped up at Low Row Service Station on the A69 (E of Brampton) on Wednesday, 18.27 litres total cost £14.05p :thumb:
lorger
lorger
9,655
90,482
Dumfries
Knaus Sun 650MEG
Thanks Mitch and Stewart seems about average.
Stewart did you make it to D&G
Minxy
32,623
66,460
E Yorks
Carthago Compactline
We're at Newark and have been chatting to the guys on the Gas-it stand about fitting an underslung tank and were quoted around £450 for a 38 litre one fully fitted, plus around another £40 if we want a digital contents gauge in the dash, so for under £500 it doesn't seem a bad price.
We already have an 11kg Gaslow bottle which I fitted in the locker (judicial use of a lump hammer made the darn thing go in as the locker is only supposed to take a 6k one :thumb: ) but we don't have room for a spare bottle and as we will be going to Spain etc in future years where gas refill points are more difficult to find apparently, we are thinking again about a larger external tank especially as we intend to keep this van for along time.
If anyone has had one fitted by Gas-it can they please let me know if they are happy with the fitting/tank?:Smile:
callumwa
4,110
4,480
Tyne & Wear, sometimes..
4 yrs +, 30+ yrs motorbike touring
That works out at approx 77p a litre.
I'm paying £19.95 for a 13kg refill delivered, which is approx 77p a litre.....:Eeek:
I'm surprised, as I thought it was a lot cheaper to buy at a petrol (gas) station.
A 47kg refill is £47.95 so approx 49p a litre.
Am I missing something........:Eeek: (again)
Apr 27, 2008
11,838
14,062
Eastbourne East Sussex
Hymer low profile
Since 1972
I'm surprised you're getting a 13kg bottle for £19 odd. The last time I bought one, a couple of years back (I have Alugas) I think it was nearer £29 for 13kg Calor propane.
Mar 26, 2009
8,158
11,215
Yr Wyddgrug
Hymer B678DL
Since 2009
I payed £20 for 6kg. Needless to say that prompted my conversion to refillable bottles.::bigsmile:
