Gas Bottle retaining straps. Is there an alternative to fabric? (1 Viewer)
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Hi All,
Just as the Heading says. Is there an alternative to the fabric tie downs that seem the norm.
I'm thinking possibly braided metal.
I've looked on Fleabay and therefore wondered if there was a Funster that knew of the goods.
Thanks in advance
TheBig1
17,604
43,079
normally the use of polypropylene straps rather than steel is to avoid sparks in the gas locker. the same reason gas fittings are brass
Emmit
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
Noted and thanks.
For some reason I got it into my head that over in Merklland they had metal straps as a matter of strength.
I can understand the 'spark' avoidance.
Dec 12, 2010
5,405
21,519
Cumbria
since 2011
Shaped steel bands with "over centre" buckles have been used on fork lifts for years.
Aug 6, 2013
11,951
16,556
Kendal, Cumbria
Le-Voyageur RX958 Pl
since 1999
A stronger retainer would then show up the next weak link in the chain - the two self-tappers normally used to secure said fabric to the locker.
Jan 28, 2008
10,113
18,366
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
most straps are useless as the fixings are inadequate the best ive seen in british gas vans are a steel ring with a flange bolted to the floor with thumbscrews which grip the base of the bottle.But in a van the floor would probably be the weakest point unless there were spreaders below or bolted to chassis
your fridge when full probably weighs more and is screwed to a bit of flimsy board
C
Chockswahay
Leather straps ?? We used to use them in hot air balloons and they worked well (y)
Emmit
Emmit
8,026
17,706
Cornwall
Pilote Explorateur
Jan.2014
I was wondering why the OP didn't want the 'standard issue' ones?
What was his perceived advantage of metal braid?
I didn't say "I didn't want" the present straps.
I was looking for something that, in the event of say ,an accident, could be construed as better.
As a result of the post from @TheBig1 I appreciate why a metal strap might be off limits.
