gas bottle question (1 Viewer)
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Evening all,
I'm out tomorrow to get a Cadac safari chef, wanting to connect to a small
gas bottle as have no external gas point on the van.
plan is to get a 3.9kg propane bottle (easier to carry around) and use it for the cadac but also as a backup for the main bottles if we run short.
are the screw connections on 3.9 and 6kg bottles the same? or is there a better option?
2dogs
43,319
49,394
same connector thread on all calor propane bottles...left hand internal thread on the bottle.
may sound obvious but dont forget you need a regulator
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks John,
no worries on the regulator .... only problem is I have 4 butane knocking about and now have to buy a propane one:Doh:
2dogs
43,319
49,394
Thanks John,
2dogs
no reason not to use a butane bottle with a clip on regulator.
of course, you couldnt then use it as a backup for the main gas supply.
Minxy
32,637
66,515
E Yorks
Carthago Compactline
Make sure you get the right safari chef though - you need the low pressure one:
Link Removed
Dubiousp
233
45
Hampshire
Eldis Autoquest
First
Good choice in the Safari Chef we use ours all the time, the roasting pan works well if you can get one.
We have an Autoquest 130 which takes two bottles, the second bottle I fitted a inline bayonet to so that I had either option of plugin to van or moving bottle or using a smaller bottle the connectors were about a fiver.
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Minx, Dubious,
LP on order, may see about a van connection another time but want to use it away (garden, beach etc) hence the reason for a small bottle
2dogs
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
I'm out tomorrow to get a Cadac safari chef, wanting to connect to a small gas bottle as have no external gas point on the van.
2dogs
Did that. Got fed up with small bottle and fitted BBQ gas point. It was very easy on my van, there was a spare blanked off outlet on the gas manifold.
2dogs
2dogs
257
73
Devon
Autocruise Rhythm
Spring 2012
Thanks Brian,
may look at the van option later.
2dogs
Dubiousp
233
45
Hampshire
Eldis Autoquest
First
Sorry to explain I didn't fit a outlet fitted inline coupler which allows me to use big bottle small bottle etc
End time: 28 Aug 2012 09:26:03 GMT+01:00
iPhone/iPad URL:
QUICK RELEASE NOZZLE 8mm LPG GAS HOSE CONNECTOR. E74
Browser URL:
Download eBay for iPad
Dave D
