The gas locker only takes one bottle
Reading this I truly appreciate the refillable systems. Like awnings that are an extra on most new vans but should be included unless you opt out of having one, the refillable gas bottles should be included. One of the first items I was offered when buying a new (to me) van, was a couple of large Propane bottles. Deduct the cost of these and the refillable bottle price would be a little more reasonable. From our first proper van to now we have always had refillable gas; it is cheaper, much more convenient, with no risk of heavy lifting or knocking the body when changing bottles.Hi. How do I find out/check how much gas remains in a gas bottle? Chausson Flash 10 (2012)
No flame = no gas . Lol.Hi. How do I find out/check how much gas remains in a gas bottle? Chausson Flash 10 (2012)
HTF does that work?http://www.southdownsmotorcaravans.com/dometic-pen-sensor-gas-level-indicator.html
Get youself one of these.
It is held against the side of the tank, moving down when it detects contents ie gas it gives a signal and lights up..........or something like that.HTF does that work?
For some reason which I don't understand, the Dometic blurb states it's "not suitable use on self refilling cylinders" I assume this refers to Alugas & Gaslow type cylinders.It is held against the side of the tank, moving down when it detects contents ie gas it gives a signal and lights up..........or something like that.
Not much good if you only have one refillable then.For some reason which I don't understand, the Dometic blurb states it's "not suitable use on self refilling cylinders" I assume this refers to Alugas & Gaslow type cylinders.
HTF does that work?
